Clay Lube
  • Clay Lube
    What can be used for Clay Lube
    Im out of final inspection
    Will Last Touch Spray Detailer or Ultimate Quick Detailer Work, For that matter Let me as the question, What will work for clay and what wont
    Re: Clay Lube
    Last Touch diluted 1:1 works. Can also use soapy water, though can degrade the clay over time.
    Dont want UQD.
      Re: Clay Lube
      Last Touch works great diluted 1:1
        Re: Clay Lube
        +3 on the Last Touch 1:1
          Re: Clay Lube
          What about Synthetic Spray Detailer , 135
            Re: Clay Lube
            No, #135 is pretty much UQD.
              Re: Clay Lube
              Well From what I have read so far the only reason not to use UQD is because of the price.
              But I have 8 bottles of it , I haven't found out why you wouldn't be able to use it, other than its a waste of money, But with 8 bottles sitting on the shelf. its already paid for
              Thoughts
                Re: Clay Lube
                You can certainly try it. But remember it the UQD leaves a polymer coating behind, so you you are going to spray your clay and surface with a click polymer coating, and then try to remove stuff.
                  Re: Clay Lube
                  Thank-you thats the kind of info I was looking for , Thank-you very much
                    Re: Clay Lube
                    Soapy water is extremely economical, but it can break down certain types of clay. For what it's worth, I've used clay magic with soapy water dozens of times and it hasn't degraded the clay hardly at all. Beats paying for Last Touch or using half a bottle of quick detailer per day.
                      Re: Clay Lube
                      As i try, i figure that UQD are just too slick, so the clay can't work at it's maximum best to pick up contaminant... so it's like the clay just glide everywhere without do much work ...
                      Proud to be part of Meguiars Family
