How to create a dark sheen on flat black plastic
Flat black looks cool when it's used to accent components rear window louvers on this Mustang. There are two problems with flat black surfaces
1) Over time the the flat black appearance becomes dull and loses it's dark sheen.
2) There's nothing really on the market targeted and the variety of different flat black components to restore and maintain their appearance.
Part of the problem is the material or the coating that makes up whatever the flat black component is varies greatly from from a thin vinyl tape used for graphics, to flat black paint used to paint components and flat black plastic which is where the pigment is throughout the entire plastic matrix of the component.
Meguiar's doesn't make a product specific to flat black surfaces just like no one else does, at least at the time stamp of the post. When left without options, a car crazy enthusiast has to take what they can get if it's shows to actually help, (solve the problem, and not harm, (cause a problem).
Meguiar's Gold Class Trim Detailer is for restoring and maintaining rubber, plastic and vinyl trim, so while it's not specifically for these louvers and the material they are made out of, it does work pretty good.
The way to use it is to gently massage this product onto the surface using a clean, soft foam applicator pad, somewhat like you would rub skin lotion onto our face. Allow to penetrate for a few minutes and then softly wipe all surfaces down with a clean microfiber to remove any excess residue off the surface.
The results are a deep, dark black sheen...
