Who carries wettable (probably not the right word, but the ones you use with water) discs for grits 1000-2000? I see only the black sheets in those grits in local auto stores.
Can't find 1000-2000 discs
Re: Can't find 1000-2000 discs
Detailing stores carry wet sanding disks for dual action sanders. They carry them in flat and padded.
Here is a link to one online detailing shop and their #M TriZact disks.
https://www.detailing.com/store/cata...=asc&q=trizact
Here is a video with Jason Rose, Kevin Brown and Larry Kozilla.
https://www.youtube.com/watch?v=BgCmrGMhvss
It does not take long (seconds) to burn through clear and paint.
No need to ask me how I know.
Stay away from edges, body lines where you can cut through quickly.
Also spend time searching and watching additional resources.
Thanks, Old Bear. . Great video, better step-by-step than others I've viewed. It's my first time spraying. It was too hot in my garage, and the clear coat came out sandy-looking because I couldn't keep a wet edge, rougher than in the video, where they start at 1500. Would you suggest a rougher grit for smoothing down the texture first? I've done the whole hood, so hand-sanding isn't practical.
And, yes, I know now I should have practiced on a small spot first.
Do I have to wait before applying Meguiars Ultimate Compound? I sprayed on 9/3.
I should have said four steps and not four parts.
Here is another resource. This is Mike Stoops with images, notes and at least one video full of tips on wet sanding. This is very good. Make sure to find the image of hand sanding that is really a video link.
http://www.meguiarsonline.com/forums...Advanced-Class
You can also get 5,000 grit discs.
Did you notice in Jason Rose/Kevin Brown Video yesterday that they showed a soft interface pad?
Did you notice how Mike Stoops hand sand video shows flat hands on sanding pad and tight soft strokes?
Did you see his image showing how "NOT" to hand sand?
Got to keep those fingers from making pressure lines.
Here is a thought.
Any junkyard or friend with a black damaged fender or hood near you for a couple bucks?
Could you take a scrap panel and paint it with the same clear and let it set up?
Then practice your sanding and compounding/polishing on that first?
