Does ScratchX have fillers?
Re: Does ScratchX have fillers?
Originally posted by Mike Phillips View PostGreat testimonial based upon your real-world experience, maybe copy and paste this to create your own dedicated thread?
Sometimes a post like this is worthy of being it's own thread as it can get kind of buried in a thread.
I put it in the Dual Action Polisher section, hopefully that's a good spot for the topic! (if not, could you move it to the most appropriate section Mike?)
After washing my car on the weekend, i noticed a neighbours cat has climbed across the bonnet ( hood ) and left heavy scratches !!!
Gave the car, in total, three applications of Meg. Scratch X .
Each application, the scratches became less noticeable,...until completely gone.
After the last buff, finished off car with NXT Wax. back to new.
Now, I'm going to go kill the cat !!
Originally posted by Patman View PostI am a HUGE fan of Scratch-X! I've got a black Corvette, and my usual method of removing swirls and light scratches with my DA has been to use either #83 or #80 first (depending on the severity of the area) then following it with #9 to get rid of any micro-marring, then finishing it off with my LSP (I'm now using NXT 2.0, but last year I was using #21)
But on the advice of another black Corvette owner, he told me to try out Scratch-X with my DA instead and it does a fantastic job! The Corvette's clear coat is pretty hard, so usually one pass with any product doesn't do much, but when I make one pass over the car with Scratch-X (on my UDM set to speed 5, with a white LC polishing pad) it makes a major improvement in my finish! And not only that, but it leaves the finish shiny with no micro-marring, so I don't need to do anything except go straight to my LSP! I also love how easy Scratch-X buffs off, it saves me a lot of time! I can now get better results in 90 minutes (including putting on the LSP!) than I used to get in three hours!
So if you guys haven't tried using Scratch-X over your entire finish with a DA yet, I urge you to give it a try, this stuff works like a charm!
I am a HUGE fan of Scratch-X! I've got a black Corvette, and my usual method of removing swirls and light scratches with my DA has been to use either #83 or #80 first (depending on the severity of the area) then following it with #9 to get rid of any micromarring, then finishing it off with my LSP (I'm now using NXT 2.0, but last year I was using #21)
But on the advice of another black Corvette owner, he told me to try out Scratch-X with my DA instead and it does a fantastic job! The Corvette's clear coat is pretty hard, so usually one pass with any product doesn't do much, but when I make one pass over the car with Scratch-X (on my UDM set to speed 5, with a white LC polishing pad) it makes a major improvement in my finish! And not only that, but it leaves the finish shiny with no micromarring, so I don't need to do anything except go straight to my LSP! I also love how easy Scratch-X buffs off, it saves me a lot of time! I can now get better results in 90 minutes (including putting on the LSP!) than I used to get in three hours!
Note that I was polishing white paint, and a pro detailer told me it was single stage. (it looked single stage to me too) Apparently white paint is very hard paint, and so it is very difficult to polish. (however, he cleaned up my mess very quickly with a rotary, as I said) I have a clearcoated car now and I might give the ScratchX another go out of curiousity. However, I also now have a rotary polisher and I want to spend most of my time learning how to use it!
Greg.
Originally posted by V8Caprice View PostI've briefly tried ScratchX myself.... I polished a tiny little area....
Also, I used a terry pad thinking it would help, but, it just absorbs the product and masks the "feel". I think.
p.s Just btw, this thread wasn't "my post", if that's what you meant - I didn't start it.Hoped no one would notice. But then.......
that's what detailers do. duh
Hi gang. I certainly don't have the answers, but I see words being tossed around, perhaps not entirely as intended. The Socratic method starts out by defining your terms. It is something I've struggled with a bit, but we need to distinguish between words like cleaner, polish, wax (or LSP if you'd prefer).
As I understand it, ScratchX falls under the category or cleaner. With the Meguiar's 5 step system of paint beautification / protection - http://www.meguiarsonline.com/forums...ead.php?t=2409 - are you not skipping a step by going directly to a LSP after ScratchX? I'm not saying it is wrong (so long as you don't harm your paint, you aren't doing anything wrong), but you may see better results incorporating a polishing step as well.
I'm far from an expert with ScratchX, but my thought on using it on a car is to use ScratchX on the worst / most visible defects by hand, then use another cleaner (Fine Cut Cleaner as one example) to work the rest of the car, then a polish, followed by wax / LSP. Mind you, my perspective is working on my Buicks...they are large cars and if I attempted to do the entire car with ScratchX, it would take me a week and I'd never move my arm again.
I hope this has been helpful, rather than muddying the waters further.
Originally posted by Jossy92 View PostArguing is not allowed and I understand that this forum has Meg-Ninjas with trained buzzards capable of hitting vehicles from hi altitudes.I have not been called a Meg-Ninja before...time to get the buzzards out again...
Originally posted by Jossy92 View PostI am going to bail out of here and go back to the 101 forum. ScratchX takes a lot of work and I still see scratches, however they are slowly lessening. I don't feel anything is being hidden. I feel I am being protected from taking too much off too aggressively.It really did work.
(I then took the car to a professional, and he quickly and easily polished the whole area with a rotary.) So yes, in my brief experience with ScratchX, I haven't noticed any significant degree of sinister filling.
Greg.
Originally posted by V8Caprice View PostIf we really really want to know what the surface of the paint looks like, without anything being hidden at all, then we could very thoroughly clean the surface.....
Greg. (a newbie too)
However, the title of your post suggests that it is an issue when it just might be one of definition: A "quibble" .... an argument over words. Arguing is not allowed and I understand that this forum has Meg-Ninjas with trained buzzards capable of hitting vehicles from hi altitudes.
Maybe we are not using the term "filler" in the manner used by the pros here and that is where the confusion lies. Also, it was suggested more research in the forums....a gentle way of suggesting a solution.
I remember reading about having a purpose and then finding the best solution. And when you share your solution you are doing "each one, teach one." I just am so new that I didn't/don't see your purpose and why is it important. Maybe that is why I am confused.
I fear I am one of the those cut and paste masters, so back I go to Detailing 101 as the more I talk the less I learn. But, thanks for clarifying.
Originally posted by Jossy92 View PostI am confused, is this a new thread about "filling effects" instead of ScratchX having fillers? I am a newbie and am trying to follow along.
Why did you change your question? I am lost.
Respectfully,
Anyway, it's my understanding from what Mike has said that ScratchX does NOT have anything in it for the sole purposes of "filling", however, it does have lubricating oils which are required for the product to work, and those oils do have the side effect of "filling". If we really really want to know what the surface of the paint looks like, without anything being hidden at all, then we could very thoroughly clean the surface after having used ScratchX. However, ScratchX is part of a system, and in fact helps to prepare the surface for the application of a Last Step Product (wax or sealant etc). So, all we need to do in most situations is wipe off the excess ScratchX, and then wax. And the wax acts as a "filler" as well.
I'm assuming that even if an IPA wipedown were done after using ScratchX (and wiping off the excess normally), that in most cases the difference would be very subtle. (has anyone ever noticed a big difference?)
Respectfully,
Originally posted by Mike Phillips View PostNo.
This comes from Zaino people, you must have read this on some other forum.
There are two threads in Hot Topics that address this, (posted years ago). Maybe take it up as a challenge to see if you can find them and post the links to them here.
Greg.
Originally posted by V8Caprice View PostGiven that ScratchX contains lubricating oils, shouldn't they be washed away before waxing?
Greg.
Keep in mind, our chemists understand the process. They make the waxes that go on after ALL the other products. One of the threads that addresses this in the Hot Topics forum uses our Mold Release Technology in an analogy and if anyone knows anything about the costs involved if you "Stick a mold", then they would understand that if it were necessary to wash off any pre-wax products we would have certainly been recommending this since 1950 when we introduced M08 Maximum Mold Release Wax.
