Hi Guys,
I've recently got some small scratches on my Titanium Silver Kia Forte and tried using Scratch X (but I think my technique was wrong when applying) a few times on the same spot, rubbing it with pressure using a microfibre cloth but the scratches still remain as you can see from the photos below (if the photos are too small, you can click on "Actions -> Download Photo" to get the full resolution photos). I tried to feel the scratch with my fingers and it doesnt appear to be too deep, looks a bit fine and its not obvious in darker areas such as an underground parking lot, but in the sun you can see it if you go closer. Anyway, here are the photos:
As mentioned I tried to apply Scratch X (the first version, not the 2.0 one) using a microfibre cloth and rubbing it with pressure onto the surface that has the scratches but they dont appear to be coming off. Is my technique wrong? I tried rubbing hard, then apply some onto the microfibre cloth and repeated it about 3-4 times. Is this the correct technique? If not, please do advice what I'm doing wrong because I believe we should be able to get rid of the scratch of this level with Scratch X, unless I'm seeing it wrongly.
