I am curious as to which type of applicator is better to use. The foam one that comes with Meguiar wax kits or a Microfiber one? Also should you always buy new applicators pads or can you wash them and reuse them?
Foam applicator pads vs Microfiber ones
Re: Foam applicator pads vs Microfiber ones
Please provide us with just a bit more information. What process will you be doing? Cleaning - like with a product such as SwirlX, Ultimate Compound, or Polishing - like with M07, Ultimate Polish or Waxing - like with Gold Class or Ultimate Wax.
What are you attempting to do? What condition is you paint? How old is the car?
Just from what you have said I'd guess you are waxing, in which case the applicator that came with the product works great. This is often a foam applicator.
Yes, the foam applicators can be washed with a liquid soap, thoroughly rinsed, allowed to dry and then re-used.
David
Originally posted by wifpd4 View PostPlease provide us with just a bit more information. What process will you be doing? Cleaning - like with a product such as SwirlX, Ultimate Compound, or Polishing - like with M07, Ultimate Polish or Waxing - like with Gold Class or Ultimate Wax.
Yes, the foam applicators can be washed with a liquid soap, thoroughly rinsed, allowed to dry and then re-used.2011 Mitsubishi Lancer GTS, Octane Blue
I like the Smooth Foam (Hi-Tec Foam) ones for everything.
Terry cloth could be used if you need more agression, but can leave its own marks behind.
I dont like how the MF over the foam feels, but others like it.2017 Subaru WRX Premium - WR Blue
Another fan of the foam pads, here. Since I could only find microfiber ones at local stores, I tried those for the first wax of the year (Caybar and cleaner wax) on the '96. Absolutely hated the feel, and it seemed to result in less shine, somehow... Maybe its just me.
Anyways, been using the foam that came with my ULW, plus I found some more foam pads at Pepboys yesterday!2011 F150 5.0L 4x4
I went to You-Tube and researched microfiber pads. I only watched videos from well know detailing sites (like Megs).
From what I saw, the pad was loaded up with liquid wax and even more liquid wax was applied to the surface before begining. Due to the amount of wax being used, the surface was very slick and I didn't see much drag.
The wax appeared to cover the entire hood (and then some) without reloading the pad and yet only a thin film covered the surface.
So, microfibre is good when you have to cover large areas without having to constantly reload?
Got to be a "purpose" that these pads accomplish better than foam.
I don't have the expertise to figure that purpose out from the videos. except the fact that coverage appeared to be uniform and "saving product" obviously was not an issue.
Somebody out there knows. Don't make us beg.Success is never final, failure is never fatal. It's courage that counts.
by John Wooden
'88 Honda
