I am very excited to try UC this weekend but i do not want to ruin my truck. I saw the post were someone ruined the whole side if thier car with UC, after reading that i think he had to much pressure on his fingertips and did not prep the vehicle. I cannot believe he inflicted that much damage by hand, that is why im nervous. I will do a test spot before i put UC all over the car. I was going to wash with GC then CLay, UC, DC2, NXt 2.0.
Ultimate Compound First use this weekend!!!!
Re: Ultimate Compound First use this weekend!!!!
Yes there are some factors which need to be taken into consideration first. So long as you do the prep work and use the right techniques and a small test spot then you have done everything correct. Goodluck with the UC i heard also that it works wonders! Post some before and after pics, we would love to see the outcome!
Im going to use Swirl X first but i am dying to try UC because of the awesome results i have seen on this website. Im hoping i can use someones garage because it is going to be 13 degrees this weekend.
Both give good results, UC tends to be the more drmatic make overs of course.
But just to be sure, you dont SwirlX everything, then UC. Just SwirLX test spot, a UC test spot if needed, then repeat what works over the whole car. If you used UC, just follow up with SwirlX if needed.2017 Subaru WRX Premium - WR Blue
Remember the rules of Gold, Always go from the least abrasive product to the more abrasive one.
You may see the order of abrasiveness in this post.
http://www.meguiarsonline.com/forums...hlight=scratchRyan's Auto Detailing, S.A
Dominican Republic.
Well it would also depend on the hardness of the paint you're working on.2006 San Remo Red WRX TR
2005 Ford Ranger XLT
Detailers clean places nobody see. Detailer see's things nobody else see. But if you ask a Detailer to see how a dress looks on a woman, they are blind.
Originally posted by GlossBoss View PostI am very excited to try UC this weekend but i do not want to ruin my truck. I saw the post were someone ruined the whole side if thier car with UC, after reading that i think he had to much pressure on his fingertips and did not prep the vehicle. I cannot believe he inflicted that much damage by hand, that is why im nervous. I will do a test spot before i put UC all over the car. I was going to wash with GC then CLay, UC, DC2, NXt 2.0.Don
12/27/2015
"Darth Camaro"
2013 Camaro ... triple black
323 hp V6, 6 speed manual
Originally posted by GlossBoss View PostIm going to use Swirl X first but i am dying to try UC
Also, you mentioned working in the cold (13 degrees). Be careful, and dont let working in the cold distract you and/or slip into doing a rush or careless job. If you are uncomfortable, it might be better to do a simple SwirlX "temporary job" and wait for better weather when you can spend the time and attention to do a really first-class rejuvination. Its just a thought, but living in Canada I often end up taking this route, since cold hands/fingers simply dont do a first-class job (even in a sheltered but unheated garage). As well, all of the products simply dont work as well in cold conditions.2010 XRS
i have tried the swirl x but it did nothing. THe person who had the car must of taken to tunnels car washes 100 times so the paint *****. I also tried scratch X which did not much, so i figured UC would be next. I would only do this if I could do it in my buddies heated garage. I am not going to rush and ruin my paint. Thanks for the advice
As long as you don't do the whole car at once, let it dry, and do it in the sun you should be fine. Definately do it in a heated garage, this time of the year is no good here in the Mid Atl/NE area.
Do a test spot, dial in your process and have at it! If you work in small sections at around a minute a pass and wipe the remaining product off before drying you will be ok.
I did my first time with UC by hand and it came out excellent!
So as I was saying in the detailing by hand forum, I am doing my wifes black Focus and as of right now it's kicking my rear end! I washed and clayed it almost a month ago and did a test on the Ultimate Compound. It did diminish the swirls a good deal but there were still some staring back at me with a cheese eatn' grin :grrrr1
This is what I achived last year on my wifes black Focus, not too bad at all by hand!For those who fought for it, freedom has a flavor the protected will never know.
Wife say's I'm "obsessed"!
Hi how are you! I checked out your thread from last year, the car looks amazing and just being done by hand that is a massive improvement with just those few products. I am wondering how things are going with the car now. Did you try to remove anymore? All in all it looks a fantastic result. UC seems to do the trick for those swirl-filled cars!
Originally posted by Aussie View PostHi how are you! I checked out your thread from last year, the car looks amazing and just being done by hand that is a massive improvement with just those few products. I am wondering how things are going with the car now. Did you try to remove anymore? All in all it looks a fantastic result. UC seems to do the trick for those swirl-filled cars!
Once I obtained a G110, I went over the car again and the car was dang near flawless. Several months ago the Focus was vandalized by a kid with nothing better to do other then spray painting my car! I was able to get rid of the spray paint using clay and UC, topping it off with #26. The trim on the other hand can't be corrected and will probably get it painted when spring rolls around.
Sorry for hijacking the thread....Glossboss, how did the UC work out for you?For those who fought for it, freedom has a flavor the protected will never know.
