It is a very mild cleaner, so there isnt really a lot you need to break down.
Is your car in good shape? If so, you can just think of it like working in skin loation, just add a little more pressure/passion behind the pad.
If you have some defects to fix, you might want to start with a different product that is a bit stronger.
Just to add to this, this product does NOT need to be left to dry on the surface. Work it around until it begins to dry, and then stop and remove the product. If you wait too long and let it dry it can create problems for removal.
It sounds like you may need to clay first to smooth the surface. The swirls are going to need a much more aggressive compound. You may also need a rotary. Swirl-X may work for you by hand or DA.
Chef and Dr. of Min.
God is a good God, He loves you, and He wants to bless you.
