Removal of vinyl and plastic pin stripes
  • Removal of vinyl and plastic pin stripes
    I received a call from a customer that wanted the pin stripes taken off her 1999 Nissan Pathfinder. I asked the customer to give me a couple of days to find out a good way to get the 11 year old stripes off her vehicle with out using heat guns and without messing up the paint. I called a friend of mine that owns a paint and body shop and asked him what he uses. He said a pin stripe eraser. He said it is made of eraser material and you connect to a drill and have the disk vertical to the stripe and don't stop moving it. So the next day I went by his shop and he showed me the eraser and how to use it, then he ordered it for me and I went to the local Car Quest and picked it up. The eraser worked like a champ and I was able to remove the stripe from both sides of the vehicle and the glue in 30 minutes. Went over the area with a paint solvent to remove the eraser residue and waxed the area for protection. Here are pictures of the eraser and the end result.
    Before with the stripes
    After
    Imagine Auto Detailing
    Re: Removal of vinyl and plastic pin stripes
    I removed pinstripes from a vehicle I used to own a few years back with a heat gun and a good adhesive remover. I have never heard of a pinstripe eraser. How did it go compared to using a heat gun?
      I know the last time I used a heat gun I kept burning my fingers, so compared to that alot less pain. lol. The eraser seemed alot quicker and the eraser residue was very easy to get off. I used some M205 and a yellow pad on my PC to polish the area and then some NXT wax.
        Wheel is the best way to go for crappy, dried out stripes.
        Since eraser wheels about $40 and very consumable. I try to pull them off with heat first.
        In my experience, GM uses the most user friendly stripes. The stripes on my 92 caprice came off with a hair dryer.
        2012 VW GLI
          $40? Where were you looking that was selling them for that much? I only paid $15 or so for the one I bought.
            Great to know. Thanks for the tip.
              That's how much 3M sells theirs for... I'll have to try a carquest wheel now.
              2012 VW GLI
                i use the eraser to remove alll pin stripes too works perfect i bought the kit 3 or 4 years ago came with the air powered tool and 15 eraser pads for around 130$
