I've been working on fixing up a 1998 Ford Explorer and it's almost time to start tackling the exterior. Today I just grabbed a bottle of ScratchX to assess what I am going to have to tackle with the paint.
So here is a test spot where I knocked off the pin-stripe decal. You can see that the sun has baked the stripe into the paint AND I screwed up with the rubber wheel stripping that pin-stripe and dug into the paint a little. I think I'm going to have to hit these areas with nicks with touch-up paint and wet sand them before attempting the paint correction.
This; towards the leading edge of the hood there is basically a line of messed up paint. This was caused by the sun/wind deflector that was on the front of the hood and filled with dirt and debris for, at the least, the past four years. I'm thinking of sanding this back to clean it up, hitting it with spray touch-up paint, and wet sanding it to blend into the hood better. I know it wont be perfect, but if it looks horrible I'll just put the sun/wind deflector back on the hood!
Will this work? Will I need to prime before spraying on something like DupliColor's matched spray paint?
