Wetsanding urethane primer
  • Wetsanding urethane primer
    After block sanding the urethane primer with 600 wet, all of the panels look very straight, but it seems that I have VERY small waves throught the entire car. They cannot be felt, but at a particular angle I can see them. The car was at bare metal to start, variprime, urethane primer that was blocked with long boards between coats until flat.
    So now after wetsanding, I see these tiny little waves. Two different painters came by and said the car is ready for paint. They both said that I will not see this when the car is finished and wetsanded. I need more input.
    Thanks for the help.
    Re: Wetsanding urethane primer
    check out this link
    3M applies science and innovation to make a real impact by igniting progress and inspiring innovation in lives and communities across the globe.
    open the dry primer sanding video and check if something from here applies.
    I know it's a commercial link, but I think it covers some of your doubts.
    I'm familiar with clear coat sanding, but not that much with primer sanding, but I hope this helps.
