Can I use m105? I have M49 but might need something stronger
  • Can I use m105? I have M49 but might need something stronger
    So i plan to polish and restore my boat this weekend. I have the meguairs marine kit that includes M49 oxidation remover. I have a feeling some spots will need something stronger. Can I use M105 if needed? I tried to order M91 but it wont be here in time so I didnt order. Can I use 105 on a wool pad with a orbital polisher? I also have 205 and UC but dont know how those compare to the marine line.
    Thanks!
    Re: Can I use m105? I have M49 but might need something stronger
    Thanks!
    Hi SX4DUDE2013,
    Yes, you can use M105 Ultra Cut Compound on a fiberglass/gel boat boat surface, however, it technically is designed for automotive paint, so it may not be the best experience. I am not that concerned of you having a bad experience for removing water spots, but if you were trying to remove oxidation, that may be a different story as M105 can gum up trying to remove oxdiation from a boat. Another option if you had to use an automotive compound would be M100 Pro Speed Compound. This product tends to do much better for boats.
    Our M67 Marine/RV One Step Compound is a great product also & my favorite for oxidation on boats even over M91, again for oxidation.
    This thread is a good reference also in case you have not seen:
    Pictures from Meguiar's May 12th, 2018 Marine/RV Care 101 Class
    Nick Winn
    Irvine, CA
    nawinn@meguiars.com
      Originally posted by Nick Winn View Post
      Hi SX4DUDE2013,
      Awesome! Thanks! I was able to get a bottle of m67. Should arrive Sat
      How much more agressive is it over M49?
        It is significantly more aggressive. It is also heavy in polishing oils; a compound & polish in one product.
        Nick Winn
        Irvine, CA
        nawinn@meguiars.com
          Nick Winn
          Irvine, CA
          nawinn@meguiars.com
            Perfect!
            Thats what I need then!
            I used M49 last season that came with the kit and it worked okay to polish up where i had some old decals but def didnt have the cut I wanted.
            So im hoping it will take care of what I need
            Can i go directly from M67 to a wax? Or should I go M67 to M49 then wax? Or M67 to the ploish included in the kit and then wax?
              Perfect!
              Old decal fading can stain quite deeply. It's a possibility it may be a more effective approach to sand the area, say try a 3000 grit, like our S6F3000 w/ S6FIS.
              We typcially go straight from M67 to a wax like our Flagship Premium Marine Wax. The only time I would see myself doing more than that is if the boat is a dark color or I am trying to get super high end results. You can always test & see if you notice a difference.
              Nick Winn
              Irvine, CA
              nawinn@meguiars.com
                Awesome!
                Yes the boat is dark grey and the top is black!
                Thanks again for your help!
                  Awesome!
                  Anytime! Feel free to keep us in touch & share before/after pictures if you would like.
                  Nick Winn
                  Irvine, CA
                  nawinn@meguiars.com
