hello
i just purchased a makita rotary buffer and i am in need of parts for it. first off, i want to use a foam pad rather than a wool pad. i used the wool pad originally when i borrowed a friend's father's buffer when using #85 on the fresh paint, but i had some swirls and holograms. i am hesitant on using wool again, so i want to give foam a try
what do i need to order from meguiars to enable the foam pads to work on my buffer.
do i need backing plate and also which pads do you recommend.?
thanks
jake
thanks
jake
