M5 Pad/Chem Selection?
  • M5 Pad/Chem Selection?
    Hey guys,
    I'm currently in the process of restoring a 1988 BMW M5 (mechanically and cosmetically) that sat outside under a cypress oak tree in Kerrville, Tx for 7 years. As of right now the black single stage paint is riddled with significant staining/oxidation and, overall, is in very poor condition. Initially, I had planned to repaint the car, but after reading through this forum for a couple of days, I'm thinking it might be possible to restore the paint given the proper equipment/chemicals are used. Based on my reading, I have come up with a list of equipment, chemicals, and a general process, that I was hoping you guys could critique for me:
    1. Wash the car with a soap that has the ability to strip grease, wax, etc.
    2. Dry with MF towel.
    3. It seems that a lot of people would clay bar at this point, however, I feel that in my case this might prove to be a waste of time based on the information I've found regarding poor-condition single stage paint.
    4. Use a heavy cut wool pad (W5000 or equivalent) and M105@ 1200-1500 rpm to accomplish initial cut. A question I have regarding this stage: Do most people prime the pad with M105 or a light spray of water? Many posts recommend priming the pad with M105 via the KBRM, however, the Meguiar's how-to video shows the instructor priming with water pre-use of #85 compound.
    5. Wipe with MF towel
    6. Polish using a foam polishing pad (Soft Buff 2.0 or equivalent) and M205@ 1000-1200rpm.
    7. Wipe with MF towel
    8. Apply LSP. Would you guys recommend I do this by hand? Also, I would like this to be a long lasting finish as the car will be (carefully) daily driven... Based on that goal, I was planning to apply a sealant (and possibly a wax) as my lsp. Options for this: M#21, Opti-Seal, Zaino, Klasse? For my pourpose, would yall recommend the sealant/wax route as opposed to the glaze/wax route?
    In all honesty, I had planned to use Lake Country pads instead of M's as they are cheaper
    Here is my equipment list so far:
    32oz M105
    32oz M205
    M#34- Idk why why I added this.. maybe for clay barring later or priming a pad... It's cheap soo why not
    3 Flat 6.5" Lake Country orange pads
    3 Flat 6.5" Lake Country white pads
    3 Flat 6.5" Lake Country black pads
    3 4 ply twisted heavy cut Lake Country wool pads
    Pad cleaning spur
    Pad cleaning wire brush
    Some type of LSP
    Are all the different pads necessary? My fear is that I'll decide not to buy the orange pads, and the wools will be to much.. or I'll not buy the wool pads, and the orange won't be enough... Same for the black/white pads. I would also like to use this same equipment on several of my dad's Supras, but they are in excellent condition and would only require minor work. Also, do I need so many of each type of pad? I've read that the single stage paint will gum pads quickly so my initial thought was to over buy instead of under buy. The last thing I want to do is start the project, and then figure out I do not have all of the necessary supplies (I'm slightly pressed for time as I'll be traveling home from school on the weekends to do the work in my parent's, haha well more my dad's, MUCH nicer garage/home shop).
    Thanks in advance,
    Craig
