Cutting pads and buffer hop
  • Cutting pads and buffer hop
    Tried out my new 7xxx pads today with M83. I noticed more tendancy to grab and/or hop than with the 8xxx and 9xxx pads or the wool cutting pads I've used in the past.
    It was manageable, I just had to pay more attention the amt. of product and how I used the buffer.
    Is this the nature of the harder foam used in the 7xxx pads - are they just more "bouncy" than the softer ones? Or could there be something I'm missing in technique? I've got more than a little experience with rotaries but 99% is with wool pads.
    I saw it on the Internet...it must be true!
    Re: Cutting pads and buffer hop
    Cutting pads tend to be a little more friendly once you use them a couple times.
    Jason
      Is this pad also slightly larger than your old pads? More surface area can make it grab more.
      I had issues with this at first myself- but with practice and learning to adjust pressure and product amount I have all but eliminated it.
        Here's an old thread about foam pad buffer hop:
        I purchased a few 8" Meguiars foam pads which I'm new to. I have been using the Rotary buffer for at least 10 years now with a ool pad. Until recently i wanted to try the foam to see if there was a difference. I put on the same product as well as the same amount and get a nasty hop to the buffer. What is the cause of this?
        Kevin Brown
        NXTti Instructor, Meguiar's/Ford SEMA Team, Meguiar's Distributor/Retailer
          Thanks Kevin, thats a great article. It goes a long to to explaining why foam and wool pads behave differently and why hard and soft foam are different too. I'm a lot like that Sellncars guy: I've used rotaries for years with wool pads and agressive compounds on boat hulls but refining automotive paint with foam pads and very fine compounds is still new to me. I'm sure I'll get the hang of it with a little more experence. Thanks again for the tips!
          I did notice that. Seems like the pad needs to break in a little.
          BTW, would a slightly higher or lower speed make any difference? I have been setting my Makita @ 2.5 for about 1200 rpm.
            No, I think you are in the range. I tend to go a little slower than most and use a little more downward pressure. I feel most comfortable in the 1000-1200RPM range.
            Jason
              Good sleuthing work Kevin and a great thread on the topic, I just tagged it with Buffing Pad Hop so it will be easier to find via the Popular Tags box.
