Spiderwebbing
  • Spiderwebbing
    i was buffing with my rotary buffer using #83 using all the correct methods and procedures with a LC Orange pad... at setting 3 or 4 out of 6... also tried #80 with LC White pad with my DA polisher
    do i need to go to a wool pad and #84?
    AJ Auto Detail, LLC
    Re: Spiderwebbing
    A picture speaks volumes got one...?
    Joe's detailing (Since 2002)
    ''We begin where the car wash Ends.''
    (269)650-2242
      Re: Spiderwebbing
      If the swirls and scratches you're trying to remove using the M83 with a foam cutting pad are not being removed then you need to substitute a more aggressive product.
      The rotary buffer with a cutting pad will leave swirls in the paint, so just to be sure, the swirls you're trying to remove are NOT being removed with the M83/LC pad?
      That is, you're not removing the swirls and then upon inspecting the results looking at "new" swirls?
      Correct?
      Also, you are doing a Test Spot? That is you're dialing in your system to a small area first?
      If the above is all correct then try the M84 with the cutting pad and only work a small section. After working the section with the M84 wipe off the residue and inspect to make sure you're removing the original defects. Any swirls left by the cutting pad and the M84 can be removed in the next step.
      The goal is to find a pad and product that will remove the original defects you're going after.
        Re: Spiderwebbing
        thanks for the help guys... ill try to move to a wool pad first them step it up to wool/M84
        AJ Auto Detail, LLC
