MF pads and product choices
  • MF pads and product choices
    I've been reading quite a bit about the MF pads and I was wondering what other products can be used with the pads. I understand that D300 and D301 have been formulated for use with the MF pads but was wondering how other products would work.
    Re: MF pads and product choices
    Every car / situation is different, but there's been a lot of successful experimenting with other products.
    I've heard of M105, M205, UC, D151, M101 and some others being used with success with the MF pads. There's even one guy (Will) who uses a mix of D300 and M105 (i.e. two drops of each on the pad) with the MF cutting pad.
    It's a matter of seing what works for you, by doing a test spot.
      Exaclty. Couldn't agree with you on what works for the defects your trying to remove and hardness of the paint. I was asking the questiuon to see what products can safely be used with the MF pads. I mean since the pads are MF, are there products to avoid. Some products dry quicker then other. Some contain a lot of oils. Etc.
