G110v2 orbit path
  • G110v2 orbit path
    I do a lot of painting and tired of hand sanding out the little orange peel (nibs etc...) in my stuff. Got some money burning in the pocket for a DA sander. I was going to go with a pneumatic but don't think my compressor can keep up with it. (60 gal with 90psi 10cfm) So looking around and found the g110 and thought that would be a great alternative. However the orbit path I need to do color sanding is 3/32 and the orbit path of the g110 is much greater (i think 3/16? or somewhere around there) What would you guys recommend? Thanks
    Re: G110v2 orbit path
    This link doesn't provide a direct answer to your question of a DA with the 3/32" machine stroke (orbit) but it does tell you that the G110 and others in the first chart have an orbit of 5/16".
      Originally posted by MaDeucePaint View Post
      ....the orbit path I need to do color sanding is 3/32 and the orbit path of the g110 is much greater (i think 3/16? or somewhere around there) What would you guys recommend?...
      The orbit diameter of the G110v2 is 5/16". For sanding, it works just fine.
      This may be a bit of a heavy read for you in one sitting, but at least eyeball the diagrams for starters:
      For quite some time I have been working on a paper about the innerworkings of the random orbital. While I have not had a whole lot of extra time this year to devote to completing it, I decided to post a modified portion of it. This section pertains to MACHINE STROKE, and how it may affect overall performance. I hope it is easy
      Lots of info to digest, but if you read it, you will know why to choose a particular stroke, or the benefit of one stroke size over another.
      Kevin Brown
      NXTti Instructor, Meguiar's/Ford SEMA Team, Meguiar's Distributor/Retailer
