Hey there guys, So yesterday I was detailing a Black Honda Fit. I washed with Gold Class and then used a Mild Blue Clay Bar. I then started off with a test spot of m80 on the m8006 pad with my G110. It sure took out the swirls pretty well however it left behind holograms. I decided to go to something less aggressive so I used m09 on another m8006 pad. It did the same thing. I am a member of f150online and a few members told me that Honda paint is soft and the m80 could just be too abrasive for it. One suggested using m80 on a 9006 pad which has no cut. Still no luck in taking the holograms out.
What do you suggest that I do to remove swirls yet not induce holograms?
Also someone said that m09 swirl remover has no cut in it but its just fillers, is this true? The bottle says that it has cut???
Thanks.
Thanks.
