From my Canadian supplier I can get the Lake Country pads much easier and less expensive , due to shipping to Canada, than the Meguiars pads for PC. I have read enough on here to avoid using the orange light cutting pad. My question is does anyone have experience with the white polishing pad and does it work well with 80 and 83? Or is this why the other sites recommend the orange because the white doesn't work well for polishing out defects. Just getting my list together and could use some advice. Thanks
compare Meg's pad and Lake Country
Re: compare Meg's pad and Lake Country
To answer your question, yes. The white LC will work with 80 or 83. I have both the Megs and LC's. I wanted to try them out and see which ones I liked better. I have a local Megs distributer so I will be getting more Megs pads when I need them. Like you it's a cost/conveniece thing.
The white LC is very close in performance to the 8006 Megs pad imho. I think the LC's will work very well, especially since they are readily available.
Tic
Anyone else have experience with this.? As I read on other sites they are using the orange to remove defects and follow up with the white. I clearly read here not to do this with Meguiars products. I think the Megs yellow 8006 must fall somewhere between the white and orange Lake Country .
Thanks in advance for your input
Originally posted by mini44 View PostAs I read on other sites they are using the orange to remove defects and follow up with the white.
Read this and look at the hazy paint in the upper left hand corner of the picture in that thread,
Cutting Pads with the PC - Good idea?
Then read the third post on the 2nd page
this is how it works
My cars: Meguiar's pads
Other peoples cars: LC pads
You must remember that the Meguiar's products are designed for use with Meguiar's pads. If you use other pads there is no guarantee that it will work. If you polish your car enough then you will see that the polishing pad is really nice to work with. But on really neglected finishs ( aka other peoples cars) I have used a LC orange pad.
Also if you have problems finding Meguair's products you can always give Greg Morton a call. But I can tell you right not that you can order them from NAPA, for about $35 a pop.
The white LC is very close in performance to the 8006 Megs pad imho. I think the LC's will work very well, especially since they are readily available.Patrick Yu
2003 Honda Accord
2008 Honda Accord EX-L V6
