That looks like a polyester/nylon blended material. If you contact the manufacturer or store where you bought them, they should be able to tell you the composition. Once you know that you can decide on the appropriate cleanser.
Those look like the similar material on my now Ex wife's Neon.
I used All Purpose Cleaner, spray, scrub and rinse with clean water and used a shop vac to remove any moisture and let it sit in sun and detailed the rest of the interior.....
Here's the link for my interior clean up of the Neon.....
Actually these seats are quite different. The blue trim has a black nylon mesh layer on top. Which I think if I use any kind scrub brush, its going to tear them up or make them "pill".
I've done similiar seats and used the following approach:
1) Shop Vac
2) Spray liberally with APC +
3) Scrub with horsehair brush (brush is fairly soft)
If I remember, I only used a mf towel to clean as I was afraid of the same thing, a hair removal brush put "scratches" in the fabric. But the APC+ with MF towel and rinse worked good.
Hope you work it out!
If the aforementioned APC+MF method doesn't work, try steaming them, or locating someone/detailer with a steamer. From the above descriptions, it seems that the material is pretty delicate, so the steam should lift out any dirt without abraiding or oversaturating the material.
