Leather furniture
  • Leather furniture
    I just bought a well used leather recliner. Can I use Megs products?
    What's best for aniline dyed/semi-aniline dyed leather that has no protection?
    A foam? Gold Class? Or, something else specifically marketed for furniture?
    Rob A.
    '07 Kia Optima (Gold)
    Re: Leather furniture
    The leather products are safe to use, but there is a greater risk of some darkening on furniture/clothing.
    So be sure to do a test spot in an out of the way place, and make sure it looks ok for you.
    You can always use a spray if you want to be carefull not to over-do it. Just mist on and wipe around. I do that with my leather jacket.
      For aniline or semianiline, which are uncoated leather, no matter what you do, test it in an inconspicuous place first. I would use a product formulated for this type of leather. I know Leather Masters has some, which I use for my semianiline sofa. A car leather product may work or it may darken the leather, so test first if you want to use one!
        Leather furnitures are easy and safe to use. Before buying it, make sure to test it. You can buy quality leather furnitures around the internet.
          I would do the test spot and go from there. In most cases, you will be fine. But , do the test spot to be sure your safe.
            Definitely test first. The products are technically safe, but could significantly darken the leather if it's uncoated.
              I used some non-Megs conditioner Lexol and was very happy with the end result.
              Rob A.
