OK, this is a new one for me. I have burled walnut trim on the inside of my new 3 Series. I just noticed today that there are nasty looking swirl marks all over the wood! I've never encountered this before. What do you guys recommend for removing it?
Swirled Wood???
Re: Swirled Wood???
do you know if it's wood that has a clear coating on it or not?
I imagine you can treat like paint but hopefully others chime in.
Best step is to find out what is on the wood (coating wise if coated....)Philippians 2:14 - Do all things without grumbling or questioning,
Re: Swirled Wood???
Originally posted by Nappers View Postdo you know if it's wood that has a clear coating on it or not?
Re: Swirled Wood???
It's a resin.
Not plastic or paint
Mike & Mike told me in another thread, there's nothing you can do with resin, except re-resin it/by new part.
I, and I'm sure you, have seen all the cracked lacquer on Mercedes dashes. Nothing makes a Benz look like a cheap import by having a cracked dash. I'm going to and fix these on mine by sanding and applying new lacquer. Shouldn't Meguiar's have products for this problem? They started out dealing with furniture so why haven't
Re: Swirled Wood???
Once a coating develops cracks in it, polishing won't undo the cracks.
Swirls are a different type of problem and if the coating is polishable and thick enough to work on you can usually fix it.
Mario, can you bring this car by one of our Thursday Night "Open Garage" events so we can see it first hand?
Thanks!
Re: Swirled Wood???
Originally posted by FiveSouthDetailing View PostOK, this is a new one for me. I have burled walnut trim on the inside of my new 3 Series. I just noticed today that there are nasty looking swirl marks all over the wood! I've never encountered this before.
What it means to remove a scratch out of anything... (http://meguiarsonline.com/forums/showthread.php?s=&threadid=7228) We get a lot of questions on our forum and at our Saturday classes from people trying to remove scratches out of all kinds of things, for example: How do you remove a scratch out of; * Glass? * Clear
Contact BMW and find out what this coating is made out of? Is it a type of clear paint like on the outside of the car or some kind of plastic coating?
Find out what it is you're working on and this will guide your decision to which products to use to remove the swirls.
Then, update this thread and it will become a useful reference for any BMW owners that have this same problem into the future.
Re: Swirled Wood???
FiveSouthDetailing, since you're new to our forum, just to point out we offer these open garage classes on Thursday nights starting when Daylight Savings Time kicks in and ending when it's over.
Since you're in Irvine, why not bring your BMW by and you'll have access to Meguiar's Staff and all our product line to dial in a system approach to remove the swirls out of the coated wood trim.
Thursday Night "Open Classes" for 2009
2009 Thursday Night "Open Garage" ScheduleMarch
March 19th - First Thursday Night "Open Garage" - Click here to sign-up
(Daylight Savings Time kicks in on March 14th)
This first class will also be an extreme makeover class as we remove the swirls and
create a show car finish on this 1954 Oldsmobile Rocket 88 Convertible.
April
April 2nd - Thursday Night "Open Class" - Click here to sign-up
April 16th - Thursday Night "Open Class" - Click here to sign-up
Re: Swirled Wood???
Originally posted by Mike Phillips View PostJust to point out, in the thread Mario's referencing, the issue Mario stated he was dealing with was paint...
Mario, can you bring this car by one of our Thursday Night...
Mike P. looked at it already.
I'll be there on the 19th.
Re: Swirled Wood???
Regardless, looking forward to seeing it...
Re: Swirled Wood???
Originally posted by FiveSouthDetailing View Post...swirl marks all over the wood! ... What do you guys recommend for removing it?Originally posted by Mike Phillips View PostPaint is resin... plastic is resin too, resin is a catch-all term.
M105 works great on everything.
Just do a test spot first.
Re: Swirled Wood???
Originally posted by Mike Phillips View PostFiveSouthDetailing, since you're new to our forum, just to point out we offer these open garage classes on Thursday nights starting when Daylight Savings Time kicks in and ending when it's over.
April
