foamy engine bright
  • foamy engine bright
    hi...i had a very slow oil leak...it was a rear valve gasket leak...and i think the new oil drops are from old oil never removed from the engine....
    i want to use foamy engine bright to remove oil and grease....do i have to use it on a cold engine only>??????
    thanks....
    john
    Re: foamy engine bright
    I would not recommend using anything liquid on a hot engine. Warm ok, and I mean warm. Engines will clean up just fine cold.
      thanks..i will do as advised
        If it is not coming off easy, try getting a soft bristle brush and agitate the surface. Helps to remove stubborn product.
        Good Luck.
