How many here use your car wash solution as your primary source of lubricant for your clay bar while claying a paint surface? Any pro's or con's...
Claying and Car Wash as Lubricant
Re: Claying and Car Wash as Lubricant
Originally posted by George Wax
How many here use your car wash solution as your primary source of lubricant for your clay bar while claying a paint surface? Any pro's or con's...r. b.
Car wash solution as a lube for clay...
I have used a clean soltuion of car wash soap in a sprayer to do my clay work. I have used Mothers, 3M and Schlegel Gray Ghost clays and never had a problem wioth the solution as a lube or the clay getting "mushy".Meguiar's Fire/Rescue/EMS, member of the Church of the Highly Reflective Finish!
Waxworks Automotive Detailing
I haven't had a mushy clay bar from using a light mixture of car wash and water, however, using Zaino quick detailer turned my Mother's and Quik Clay into goop. Easy to squish around to a clean side and my guess is not help the clay pull contaminents.
SunnyDetailing is like playing music.. the more you practice, the better you become at it.
I've also used a little bit of car wash soap and water as lube. It seemed to work fine, but left some soapy looking residue behind. And I'm not one of those people who re-washes the car after claying.
But I have come up with a new method I plan to try out next time I wax my car: First I'll wash the car like normal. Then while it is still wet I'll quickly clay it. And because it is still wet I won't need to use nearly as much Quick Detailer. Plus, since I towel off each panel as I go, the car will be dry and ready to wax when I'm done claying.
Does that sound like a good method?? What do you guys think?
Slats-------------
John 17:3
This car is BMW 735 that need to clean overspray after he fixed his spoilor at body shop. I used overspray clay from Meguiars.
The result is quite sticky sometime when hand moved too slow.
Mushy means sticky and soft right? I am not sure the meaning sorry no Dictionary close to me.Varong
iamwashmania.com
Wash& Wax * Wash Mania
Just a suggestions.....
Try mixing Final Detail D51 with water 1:1 or 50/50.
It cuts your cost in half
optimizes the cutting or power of your clay
Will lubricate sufficiently and not allow clay to stick
Benefit over using car wash, you can wipe the detailer off and go right to cleaning, polishing, and waxing. As opposed to rinsing off the wash solution and drying.
Some will use wash solution after thoroughly washing and rinsing vehicle (allow rinse water to remain on surface) and then rinse/dry after claying has been completed....Man did that make sense???
Do it right the first time
Hi Jeff,
That made perfect sense.
Welcome to Meguiar's Online!
For anyone that might not know, Jeff is the Senior Area Sales Manager Meguiar's in Northern California, and an extremely accomplished Professional when it comes to the art of polishing paint and all other aspects of car detailing.
I'm happy to see your first post here Jeff!
Welcome aboard!
