need help with removing swirls with the products i have
  • need help with removing swirls with the products i have
    hi guys,
    been out of the detailing hobby for a couple of months...
    i have a gun metal car that i will need to detail after months of neglect...
    it has come up with a heap of scratches, and spider webbing
    the same as seen in this pic:
    now all i have in my garage is meguairs polishing pad, scratchx and swirl remover 2.0...
    the rest of the range includes NXT wax, carnuaba wax, paint cleanr and polish.
    will this be sufficient enough to remove some of the spider webbing?
    problem is around wehre i am, there aint much of a range with meguairs professional line...
    i have seen medium cut and fine cut product on teh shelf, but that store is 20 minutes away...
    i also cant get my hands on a cutting pad, so ill have to do with the polishing pad.
    any tips would be greatly appreciated
    thanks
    When you say "Meguiar's polishing pad", it makes me think you have a machine to use. What kind?
      i have a GMC random orbital buffer...
      its almost the same as the porter you guys have
        which product out of these would remove sratches like that?
        #83?
        #1
        #2
        as those are the only products in store
          Originally posted by tomee
          which product out of these would remove scratches like that?
          #83?
          #1
          #2
          Go with M83 or ScratchX by machine, ScratchX by hand only.
          Do not use either the #1 or the #2 with your orbital polisher on a clear coat.
            thanks for you reply mike...
            wil all prodcuts ranging from #80 to #83 be ok with a random orb?
            and why cant you use #1 or 2 with a random orb?
              Read this,
              Can you rank these from most agressive to least agressive: fine cut, med cut, heavy cut, #84, #85? I understand that all of these need to be applied by a rotary and either a red pad or wool pad but can someone explain to me how #84 and #85 differ from the rest? Thanks for the help.
              for more reading, type in
              traditional mirror glaze
              Into the search button here,
                Yes -->if<-- the tool you're using has at least as much power as the G100/PC
                If it has less power than they will still work, but it may take longer. The idea is to work the diminishing abrasives into and against the finish to force them to take out little bites of paint, as you do this they break down and stop working thus they polish-out.
                The less effective your tool, the less effective the product.
                Pretty simple really.
                  thanks again for the reply...
                  and thanks for the info..
                  my random orb has the same power as the porter...
                  looks like ill be out finding 80 series
                    good luck with that finish, let me know how it turns out
