fustrated
  • fustrated
    i am completely car crazy, so all the swirls i have right now are fustrating me.
    my problem is the common one...the infamous swirls..arggggg
    i have read many posts in many forums. none of them have showed me results, or at least get rid of the swirls.
    so i am about to go on a rant about what i do and how i can get help from this forum...bear with me please !
    Most of my owned products are meguiars.Here is what i have to my disposal to work with, please guide me to what i do wrong.
    I own a SuperBlack Nissan 350Z.
    NXT Generation™ Speed Detailer
    G12924 NXT GenerationTM Tech Protect
    G12824 NXT GenerationTM Spray Wax
    G12718 NXT GenerationTM Tech Wax
    G12711 NXT GenerationTM Tech Wax Paste
    G13324 NXT GenerationTM Glass Cleaner
    G13005 NXT Generation™ All Metal Polysh
    G10810 Gold Class Trim Detailer
    A2116 Deep Crystal System Polish
    G1116 Quik Clay Detailing System
    Deep Crystal System Paint Cleaner
    ScratchX
    Quik Wax
    Water Magnet Drying Towel
    High Tech Applicator Pads
    Even-Coat Applicator
    Supreme Shine Microfiber cloths(about 10)
    Ultra Plush Super Terry(6)
    7" random orbital buffer
    Zwipes Microfiber cloths (about 50) http://www.zwipes.com/
    My detailing session begins with a little meguiars.com motivation tips. Usually because i live in a condo and cant wash my car myself i take it to a hand car wash. Then i go home and start claying the car at the same time using a zwipes microfiber cloth to wipe the residues and lubricantaway off and leave a clean smooth surface.
    Another question i have is to how much pressure should i use when applying all pruducts, as well as to how much pressure removing them. maybe too much pressure create more swirls.
    Further on, after claying is done, i use scratchx with a Even-Coat Applicator, sometimes i use the buffer too, the amount of product i would use for this would be a 1 quarter size(the actual size of the coin here, not a quarter of a bottle) squirt from the bottle and 3 quarters together high. I rub into the paint finish as if i was washing dishes with a sponge. i spend 10-15 minutes rubbing into the finish of each panel approx. Pressure is applied. Some times wiping off the product it leaves oily finger marks, i have to go over the same spot sometimes because i see from an angle long oil rubs from my fingers of the MC.i get the Same exact results eitherway, hand or buffer. removing of this product is done with MC by meguiars. Sometimes i decide to run a second hand of scratchx because i wasnt satisfied with the first, then the product WILL NOT COME OFF. I have to rub with a great deal of power on the second coat of scratchx, and i am still on my first front section of my car only and a sore shoulder already.Maybei use too much product or too less and thats why the second coat wont come off. i dont know
    When finally it is removed(somewhat) i apply Deep Crystal System Polish with a Even-Coat Applicator or the buffer sometimes. Same pressure as above, only this time polish remove with a great EASE....to a point that it is rewarding for the previous scratchx removal procedure. MC by meguiars is used to remove the product again. Normally i wont do a second hand here, i have done in the past though. same amount is used as scratchx.
    After polishing, i apply wax. Now i have a great variety of waxes. including the Zaino sereis, mothers, zymol. i prefer meguiars. usually NXTGenerationTM Tech Wax. The easiest for me. I apply it with the pads provided upon purchase or with a Even-Coat Applicator. the use the MC by meguiars to remove wax. i usually let the wax sit for about 30 minutes on each panel before i remove it. then i apply a second coat of wax and let sit for about 15 minutes and remove.
    Two days later, i might follow the exact same wax only procedure mentioned above.
    the results?
    i dont like using scratchx, although i always do with every detail session i have with my car. it never comes off smoothly is my huge complaint. although there are remarkable results done with the scratchx, standing within 5 feet of the vehicle i can see a few swirls still. drives me crazy...sometimes i wonder why all this effort when i know they will probably still be there. the second hand residues that require a great deal of pressure to remove as mentined above is a great turn off though. could this be due maybe to some existing wax residue not removed by claying and washing that now after the first hand of scratchx it rubs it off ?
    polishing is a beautiful thing, easy on, easy rub, and comes of very easy, the car now is shining, although it did after scratchx too. but now its REALLY shiny. i like the results, now the shinyness is taking my view off the swirls BUT they are indeed still there visible. maybe a second hand of polish makes it shine more but maybe it me wanting to believe that...i am aware of the term "point of diminishing returns".
    Wax is my favorite task, because 2 1/2 hours of work is about to pay off. Indeed it does, my car is the deepest ever i have seen it(i always say that). I can shave right of the reflection. BUT THE SWIRLS ARE STILL THERE. most of them very fine and minute...others perhaps covered and concealed by the wax and polish effects. but they are indeed there, mostly visible now under any flueresent light within 5-6 feet away...
    during the week if it gets rained on i will use the speed detailer and a MC to quick mist and wipe-wash the car.
    Or if it gets dusty i will use the california duster to dust it.
    5-6 days later of everyday driving(2-3 miles a day) i start to see more visible swirls and webs. i might get it hand washed, the go home and apply a wax procedure mentioned above, which will improve the webs and some swirls...3 weeks later after all this i will redo the ENTIRE clay, scratchx...etc....these cobwebs and swirls created are they actually fine minute scratches on the layering of the wax? or is it actually that wax is compleely removed and the paint finish now is being exposes and un-conceiling the defects and making it worse?
    i park indoor during the night and day. only time exposed to outside is when going to work, which then again garage parked.
    I live in chicago...rainy and windy.
    I possibly might need to do a professional job by rotary buffer, i prefer to avoid this because last time i had this done they burned my paint on the hatch of my car. i had to repaint the entire hatch and spent $800.
    i tried to provide as much info as i can in order to get some corections, tips etc as to what to do or am i doing something wrong. i apologize if i jump and scatter all over the place in this post...
    any recommondation would be greatly appreciated. am i using the right stuff? do i need more? am i doing too much? is it useless trying any harder? any meguiars workshops in chicagoland area?
    thank you
    xtos
    There are limits to what scratch-x can do as I have found out. I ordered myself a Dual Action (DA) polisher last week. You may have to go to the next level for swirl removal (not cover up) using the proffessional line of products.
    Also, remember:
    http://img73.imageshack.us/img73/546...mallgz2.th.jpg
      "Usually because i live in a condo and cant wash my car myself i take it to a hand car wash. "
      Are you washing the car yourself? If someone else is handwashing it, this could be the source of alot of your swirls. Who knows how they take care of their washmitts, towels, and buckets of wash water.
      "I possibly might need to do a professional job by rotary buffer, i prefer to avoid this because last time i had this done they burned my paint on the hatch of my car. i had to repaint the entire hatch and spent $800. "
      The "professional" should have payed for this, not you. Do you own a PC? If not, get one. It will be the best investment for detailing you will ever make.
      Black......the ONLY color!
        I couldn't have said it any better myself! The only thing I would add is to get some #80 and #83 to use with the PC. Start with the #80. If you need more cutting action use the #83.
        RamAirV1
        2006 GTO Impulse Blue
          are all these very harsh and abbrasive to the finish?
          i like to detail VERY often. i dont want eventually to fade the finish away and need a new entire paint job.
          the hand car wash i go to they used to use there own towels and mits. now i give then my stuff to use. i give them two magnet towels and two Ultra Plush Chenille Wash Mitts. Yeah i know they probably think i am a bother but i did buy a full year unlimited washes. now i just tip them, so they know i am car crazy and are EXTREMELY careful.
          the PC is much different and better than a random orbital buffer?
          the one i got is a Vector 6" random orbital waxer/polisher .5amp.(http://www.ekitchengadgets.com/ve6raorwapov.html)
          I know if i do a little research i would find my answers, but there is thousands and thousands of threads to go through, now at least all my advice from all of you would be concetrated to this thread so when before my detailing session begins i can use it as reference.
          thanks
          xtos
            No they are not hard on the finish at all. You don't have to worry about wearing down the paint finish. Someone here did a test with a paint thickness gauge to see how much the paint abraded and you would be surprised at the results, even when more abrasive products than #83 are used. I'm sure someone else will chime in with a link the thread.
            A standard random orbital is no contest with the PC. And even novices will be able to use the PC safely. The results obtainable with a PC cannot be matched by hand, regardless of the product. #80 or #83 applied by a machine will deliver quicker and better results than with Scratch X.
            If you have a black or other dark colored car, a PC is mandatory!
            RamAirV1
              Something I have learned about detailing is when to keep my "mitts" of the car until it is only necessary.
              By this, I mean that each time you do something to your car's finish, there is always the potential to cause scratches and swirls.
              Case in point: Every morning before work I was quick detailing my car. The car would look awesome all the time, but over the course of a few weeks, I noticed more and more swirls forming!
              This is where I learned to hold off and give my car a proper wash, instead of quick detailing the stuff away.
              Proud owner of the finest looking car in the parking lot.
              Switch to Linux. Use energy efficient lightbulbs and appliances. Keep your car well maintained and drive easy to save gas. Eat less fast food. Call your mother and tell her you love her. Try flying a kite. Read a wikipedia article daily. Use Meguiar's.
                so i should use a portercable rather then the random orbital buffer that i have or by hand. which one ? any particular size?
                Instead of scratchx i should use #80 or # 83.
                is this stuff easier to handle than the scratchx incidents i keep having?
                should i continue using the polish i already use?
                or should i use something else?
                does polish require the portercable too?
                is there something i need to replace or add to my collection below?
                Currently owned:
                ScratchX
                Quik Wax
                thanks everyone
                xtos
                i am working on the pics
                  Anyone else..anything else?? before this thread dies down this list???
                    You can use the #83 and #80 by hand as opposed to by PC, but it'll be a *lot* of work, esp. the #83. So yeah, I'd get the Porter Cable. They're all basically the same machine, just fitted with different size backing plates (the velcro-faced thing the pads stick to) and counterweights (which are based on the size of the backing plate). FWIW I use the counterweight for the 6" plate with everything. The plates/weights are easily changed and are very inexpensive.
                    Yeah, the #80 and #83 mildly abrasive, but that's what you need to eliminate the marring (swirls). You need to "sand the paint smooth" with abrasives to get rid of the swirls the way you'd sand a piece of wood to rid it of scratches.
                    No way would I let anybody else wash any of my vehicles. That's almost certainly where the marring is coming from. Washing without inducing marring is much more difficult than most people could ever imagine. Note the basic problem- you're trying to move potentially abrasive dirt off the paint without pressing the dirt *into* the paint while moving it off. Every speck of dirt on the car is like a little piece of sandpaper...
                    Practical Perfectionist
                      thank you...very understanding.
                      i bought a PC from autodetaingsolutions the meguiars brand. hopefully i will recieve it in due time and will not by on backorder.also i got with it 6 8006 pads and a backing plate...
                      ....i have three tubes of scratchx, none of 80 or 83 yet. should i also buy any other pad i might potentially need?
                      also, to my understanding it is that i should apply the swirl removers/paint cleaners/polishes with the PC and use meguiars MF to remove by hand....wax should be applied by hand and removed by hand...
                      any particular comments or reasons for that?
                      also is this the polish recommended?
                      my car is a black non metallic color(Superblack 350z)
                      also, a recommondation of how to use my products i already own would be appreciated, i simply confuse which order i should use these. all my currently owned products are above.
                      Thank You all for your replies and views.
                      xtos
                        I think the fact that you take your car into a hand wash is what is causing the introduction of swirls into your paint.
                        Erik Mejia
                          I'd get 1 or 2 9006 pads for application of wax/sealant unless you really like doing it by hand. Apply with light pressure on a speed of about 3.
                          I would absolutely invest in some #80 - get a sample size from Rick at ADS. If he hasn't shipped your order yet, maybe he can add it before it comes.
                          As above, there's no reason why you couldn't apply and remove the wax with the PC. To remove the wax, just place a MF bonnet over a clean pad and use light pressure on speed 5.
                          I'd get the #80 and use that and the NXT wax - great combo! You may want to try a product like #6 for times in between full detailing for paint cleaning, wax removal and light polishing.
                          xtos
                          My comments on your products (as minimal as they are) (my comments, not your products)
                          NXT Generation™ Speed Detailer - good
                          G12924 NXT GenerationTM Tech Protect - good
                          G12824 NXT GenerationTM Spray Wax - good for between wax "pop"
                          G12718 NXT GenerationTM Tech Wax - good
                          G12711 NXT GenerationTM Tech Wax Paste - stick with the liquid as it's much easier to apply to the PC pads
                          G13324 NXT GenerationTM Glass Cleaner - haven't used this, so no comment [NC]
                          G13005 NXT Generation™ All Metal Polysh - NC
                          G10810 Gold Class Trim Detailer - good for use on external black plastic
                          A2116 Deep Crystal System Polish - consider using #6 instead
                          G1116 Quik Clay Detailing System - I really enjoy this product. Plus the '06 version comes with a new MF
                          Deep Crystal System Paint Cleaner - as above, consider replacing this with the #6.
                          ScratchX - keep for hand application to the inevitable scratches
                          Quik Wax - NC
                          Water Magnet Drying Towel - get one more!
                          High Tech Applicator Pads - buy a lot of these! I have about 10.
                          Even-Coat Applicator - I use the foam ones more
                          Supreme Shine Microfiber cloths (about 10) - 10 is a good start
                          Ultra Plush Super Terry(6) - good to have around for extra "umph"
                          7" random orbital buffer - OK for removing wax maybe, but since you have the PC now it's not worth much
                          Zwipes Microfiber cloths (about 50) - be REALLY careful with these. I don't think they are very high quality MF's and may be scratching your paint! These can be delegated to things around the house like dusting, maybe. Stick with the Meguiar's!
                          Black 2004 Ford F150 FX4
                            AFAIK, the Deep Crystal Polish (step #2) is functionally nonabrasive. It will conceal marring and impart a nice shine, but won't mechanically remove the marring. It's in the same ballpark as #3/#5/#7/#81, functionally-speaking.
                            I'd get some 9006 finishing pads too.
                            I like applying most all products by machine and I also remove LSPs with it and some MF bonnets. I use a 7006 pad under the MF bonnets.
                            Yeah, get the #80. Very good, versatile product. The #80 seems to leave enough trade-secret oils/etc. behind that I seldom seem to need anything between the #80 and my LSP, except in very rare cases (e.g., unusually soft paint and/or older single-stage paint).
                              Golly, you have a lot of "stuff". Just forget you have most of it. You've already ordered your pc and pads. For a fresh start on a black vehicle: (See my signature. I "know" black.)
                              1) #83 with an 8006 pad, pc at about 5. Remove by hand with a microfiber polishing cloth.
                              2) #80 with an 8006 pad, pc at about 5. Remove by hand with a microfiber polishing cloth.
                              3) NXT Tec Wax with a 9006 pad, pc at about 3. Remove by hand with a microfiber polishing cloth.
                              And 4) If you are truly obsessive, wait 12 hours and top with #16 or #26 paste wax. Apply by hand with a high tec applicator pad and remove with microfiber polishing cloth.
                              Then be darn careful with how you or others wash your car.
                              If all this is too much, buy some ColorX. Apply it with your pc and an 8006 pad at about 5. Remove by hand with a microfiber polishing cloth and go for a long ride.
                              Tom
