wheel stains
  • wheel stains
    I have an 04 black z71 with the factory clear coated wheels and they stains on them from what appears to be the spray on tire foam. I tried several different things to get it off but no success, could you reccomend anything?
    What did you try so far?
      I have tried the all metal polish, clear plastic cleaner and polish and even scratchX with no results.
        If a paint cleaner like ScratchX did not remove the defect or improve it in any way, the it would appear the stain effect is to permanent and/or deep into the clear paint to fix.
        Did you work the ScratchX aggressively against the clear paint?
        Note: I moved this out of the FAQ section and into Detailing 101. The FAQ section isn't open for new posts, it is open for replies.
          What kind of tire foam permantly etches your rims? I dont want to use that stuff
          http://img73.imageshack.us/img73/546...mallgz2.th.jpg
            It was armorall tire foam
