using a rotary for the first time tomorrow, help!
  • #16
    You can see there are some "spots" that showed up overnight (must have been some water hiding in crackes) it kinda gives a reference to the finish.
    • #17
      • #18
        • #19
          • #20
            here is a picture of a deep scratch that was inflicted from a kids bicylce handle bars, what do you all think would be the best approach to fixing it?
            I was thinking, touch up, let dry a couple days, wet sand, then buff?
            • #21
              I'm gonna take the wide angle lens off and see if I can get some closer detailed photos..
              • #22
                This next series is at a higher quality without the wide angle lens
                • #23
                  • #24
                    • #25
                      • #26
                        in the above photo you see the reflection of the blue crown vic I'll be doing next.
                        Here is one from the side of the scratch, a guy walking his dog just happen to be walking by.
                        • #27
                          the sun came out, this is direct sunlight (the next 2 photos)
                          • #28
                            so what do you think, tips/suggestions?
                            • #29
                              Originally posted by 2hotford
                              Yes, #80 Speed Glaze is more aggressive than #82.
                              It goes #82, then #80, then #83 in terms of aggressiveness.
                              Whoops; my mistake, I appologize....
                              • #30
                                Hey,
                                I am glad it turned out for you!!! Please post some pictures, with some in the direct sunlight.
                                Start with #80 Speed Glaze with a W-8006 Polishing Pad and the rotary spinning ~1300 RPM. If this does not do it, then move on to #83 DACP, then step back down. Use a separate pad per product.
                                I'm curious does #80 and #82 have diminishing abrasives?
                                Actually do all of the professional line have diminishing abrasives, if not how can you tell?
