Mercedes Color Discoloration
  • Mercedes Color Discoloration
    Click image for larger version  Name:	clear_coat_damage_w205_fdadb55491c0f56f26daa72030d1a1b0297b9c25.jpg Views:	0 Size:	44.6 KB ID:	912206
    I'm a neophyte so I have no idea what I'm dealing with. I'm 3rd owner. The paint is Mercedes Tenorite grey metallic
    755/7755​. I only can see it in direct sunlight and not in the shade. I used Meguiar's Ultimate Polish
    and it appeared to improve. I think I'm doing this all wrong.
    I don't want to wet sand. Could I use a polishing compound or something else that is safer?
    Is this oxidation or clear coat damage? Opinions?
    Pics aren't showing for me
      Maybe try a spot with Ultimate compound and see how that spot looks after.
        Click image for larger version  Name:	clear_coat_damage_w205_fdadb55491c0f56f26daa72030d1a1b0297b9c25.jpg Views:	4 Size:	44.6 KB ID:	912208
        Uploaded pic via URL. I tried to find Clear Coat Safe Polishing Compound but it appears discontinued. I'll look for ultimate compound. Thanks.
        Click image for larger version  Name:	59322_W3.jpg Views:	2 Size:	38.0 KB ID:	912209
          This looks like oxidation, UV exposure, or early-stage clear coat failure. If the discoloration fades temporarily after polishing but returns, it may be a sign of uneven clear coat wear. Instead of wet sanding, try using a mild polishing compound with a soft foam pad, working carefully in small sections. Follow up with a paint sealant or ceramic coating to provide added protection. If the clear coat is already thinning, polishing will only offer temporary improvement, and a professional refinishing might be necessary in the future.
