Today I decided to detail our black CRV. I washed and clayed and cleaned/polished with #80 and a polishing pad. I decided to see what #81 would add to the look I get from #80. It didn't take long before I was wishing I wasn't curious what #81 looked like. I put a small amount on a foam pad and started to apply it. I made about 4 circles with it and it turned to gum and didn't want to spread anymore. I kept trying to spread it out and work it in, but all it did was get gummier. So I tried to wipe off what I had on the paint. That didn't work either, it just left smears that would not wipe off. So I thought that maybe it needs to sit for a while. So I left it sit and came back to it and it still would not wipe off. The only way I got it to come off of the paint was to grab my #80 and a foam pad and reclean the area I had tried #81 on. So then I got a brand new pad and shook the bottle to with in an inch of its life and applied just a drop to the pad. I was thinking maybe I used too much or my pad was not as clean as I thought it was. I had the same results and ended up applying #80 again to get off the smears and streaks left behind by #81. So I grabbed another brand of polish and applied that to see if I would have the same trouble, but it went on and off easy with no problams at all.
The temp was 75 deg with low humidity and I was inside of a garage, so sunlight was not a factor.
So my question is, what am I doing wrong? I can't believe that this is normal for #81. Any answers would be greatly appreciated.
