So I recently had to put my truck in the body shop and then a month later had put it back in to have some more work done. I got it out last time on a week ago. Well this morning I stop at my regular car wash on way home to rinse it off like I do every few days to get bugs off and just road grime. The stall I went in this morning ended up acting really weird and I believe it could possibly sprayed the wax on it. I went to another stall and washed off with the high pressure water. I know some say 30 days before wax and others say 60-90 I normally wait about 75-90 before I use any soap or anything with wax. With this being said should I worry about if there was wax sprayed on by accident on that fresh of paint ? Is there anything I can do or would the damage already have been done?
Wax On Fresh Paint!!! OOOPS
Re: Wax On Fresh Paint!!! OOOPS
Originally posted by mis3 View PostHigh pressure water is probably not a good idea for fresh paint.
I read that polish is OK for fresh paint, maybe you can try it. Also, if you are concerned about wax, how about Damn?
It is fine. If it was going to lift it was going to lift after the paint out gasses too.
The wax from the coin op is not that durable so I would not worry about it. Do what Das mentioned and mix a little APC into your wash. That should remove it given that the spray wax used is not durable.
Originally posted by mis3 View PostReally? I use Meguiars paint cleaner myself and did not try Dawn. I did read in this forum that it removed wax.
