Is it ok to use the MF Correction Compound, Polish, and Finishing Compound on a clear mask?
Is it OK to use Microfiber produts on a clear mask?
Re: Is it OK to use Microfiber produts on a clear mask?
Whoa.. hold on a second... I have an Xpel clear mask around the entire front of my 4runner hood and all. Xpel is very clear in their documentation on what to use to clean it and what not to use. Do you know the producer of the mask you have? If you do, I would contact them. If you can't get any information from the manufacturer at least do a test spot in an out of the way area and see how it turns out.
You might also try contacting http://carprotectionpros.com/index.php (916) 220-4554
They state on their site..."Abrasive polishes and/or rubbing compounds should not be used on a clear bra."
Good luck
