Cooler weather?
  • Cooler weather?
    When is it to cold to wax and polish your car? Is there a temperature where it's kinda a cut off for waxing?
    Re: Cooler weather?
    I have done mine at 50F and other than a tad longer drying time, it was fine. Probably would be fine even at a lower temp, but no experience lower than 50.
      Re: Cooler weather?
        Re: Cooler weather?
        Thanks fellas. This site has already anwsered a lot of my questions. Wish I would have found it sooner
          Re: Cooler weather?
          I just did my car but used Hi-Tech Yellow 26. Came out okay. Good shine and depth. Temps were in the 40's. Under 50 degrees out I stay away from the waxes that need a cure time like NXT 2.0 but wanted to get something on the car before it gets really cold. Did two coats and spray wax on top then next day Ultimate Quick Detailer. Finish is now slick and slippery and reflects like a mirror.
            Re: Cooler weather?
            When the weather is cool, you can work in the sun, which helps.
            You may get a little streaking from wax if it is damp.. but nothing damaging, no rain not to take care of things.
              If you have a warm garage then you can do it year around but as everyone else states 50 degrees is usually the cutoff for any kind of correction work or wax.
                Re: Cooler weather?
                I was lucky enough to pick up a bottle of Paint Protect 365 at my local Advanced Auto for 4.75...used it yesterday..is it ok to now go over it with UQD..or UQW...
                  Re: Cooler weather?
                  I would wait after the 24 hour cure time stated on the back of the label before topping it.
                  Will it hurt anything, probably not.
                  If you want to get the full effects of 365 let it cure for 7-10 days.
                    Re: Cooler weather?
                    If it rains will that affect cure time within the 7-10 day window..
                      Re: Cooler weather?
                      I'm going to go out on a limb and say no. The bottle states a 24 hour cure time.
                      Mike Stoops had stated somewhere in regards to the 7-10 day window. I can't recall off the top of my head. If I find it I will post it.
                        Re: Cooler weather?
                        Yes I know the bottle says 24 cure time I just wasn't sure if exposure to water would affect the cure time..
