piano black trim
  • piano black trim
    i have piano black shiny trim in my new ford edge.. i was wondering how to remove swirls from its surface without making it worse.... would scratch x work or should i use plast-x to see if it will remove them ....
    MY NEW WORD "SWIRLFREENESS"
    FOR ANY CHRYSLER 300/DODGE MAGNUM/DODGE CHARGER/ DODGE CHALLENGER VISIT WWW.LXFORUMS.COM
    Re: piano black trim
    I would start with something a bit milder like a Cleaner Wax, or UP on a test spot first.
    If that doesn't work, then maybe you could step it up to ScratchX or PlastX applied gently on a foam applicator.
      It sort of depends on just what the surface treatment is. If it's black plastic, with color through and through, it could be a bit tricky to correct. Davey's suggestions are what we would go with in this situation. If, on the other hand, there is a clear lacquer finish over it, then you're basically dealing with clear paint over a black substrate and you can treat it like any other paint. Even the finest wood trim in the most expensive hand built cars (think Rolls Royce and Bentley) are lacquered over and can actually be machine polished and compounded/polished/waxed just as you would with any other paint.
        well see the thing is i tried plast-x ... didnt touch it.. i put gold class wax and it looked to help a bit probably filling some of the swirling.. there are no real deep scratches just swirls.. think i should try scratch x? i also ordered the novus plastic polish kit and ill try that out with its 3 step system.. and see where it goes.
          I'd try UP or SwirlX next. They are not quite as aggressive as ScratchX.
            UP works really well for this. I tried it today on the wooden trim of my Volvo and and it's like new now.
              ok will do .. tried the novice polish.. step 2.. made it worse.. luckily i used it in an inconspicuous spot uner the arm rest.. but i will give swirl x and UP a try i mean what hard can be done now haha.. i mean its only a 30k dollar vehicle right
