Claying - Hearing and Feeling Contaminants?
  • #16
    Re: Claying - Hearing and Feeling Contaminants?
    Well that's good news. Did you apply a wax afterwards to protect your hard work? When you are ready to do another correction an iron remover comes in handy.
    • #17
      Hi,
      Today morning I washed my car and started the detailing step 1. I have to apply compound , polish and wax.
      I washed the car and dried it using megs magnet MF. Then I used carpro ironx on the paint. The smell is very bad but still i sprayed te entire car . Took a sponge and spread the product across the all the panels. After five minutes I the car again. Now the paint felt smooth. But since my car is just two months old I did not much difference in the smoothness, though i have seen some iron contaminants bleeding out my car paint(can not observe as my car is black color).
      I have some questions about the process.
      1) will five minutes make the ironx work on the paint
      2) i just rinsed my car with water is it safe and recommended.
      Thanks in advance.
      • #18
        Hi guys,
        Yesterday night I did claying on my car. But to my surprise I did not see any contaminants getting picked up by te clay bar. It may be because I used Carpro IronX prior to claying. So I stopped the claying step and proceeded to ultimate compound and polish.
        I did everything by hand. There are som many swirls on my car as I have mentioned earlier, but UC worked like a magic and removed 90% of the swirls marks and made my paint look awesome. I applied light pressure while applying te UC and buff'd it with a MF. May be the DA will remove 100% swirls marks. But I am quite satisfied with the result. Then I applied polish which gave the paint lbdeep glossy look.
        I love meguiar's products.
        I did just one panel my trunk in ine hour since this is my first time.planning to finish the entire car today.
        • #19
          Google the baggie test. That will let you know if you need to clay or not.
          • #20
            IF you do not feel any with the bag the clay is a wasted step IMO Also when I clay i do not apply pressure I only let the clay glide over a very wet surface. Lots of lube and back and forth motion. IMO.
