Hey guys, I have been using UC with 205 on my 06 Onyx Black Lexus with very good results. However, there have been some deeper defects and bird droppings which I have had difficulty removing with this system. I am using a Griots DA with Griots orange polishing pads and black finishing pads, and I can't really complain with the results. As far as some of the deeper defects, after several passes they are removing slower than I would like. After reading everything on the DAMF system, it seems it will cut very quickly with D300, and I can finish with foam and 205. The DAMF system is quite appealing due to the reduced project time, and the reduced amount of product (foam pads specifically) required. I have yet to try 105 or a more abrasive pad, frankly, I'm not sure which pad would be a good choice, for removing the deeper defects. After seeing all the posts on the DAMF, it seems that it is a phenominal system, or should I try 105? The beauty of the paint on my car, is that it hides defects much better than other black cars I have seen. There are still quite a few defects which can be seen under artificial light (high powered LED), but are nearly invisible in the sun. I want to try the DAMF, but not sure if I will get much better results that what UC/205 is providing. Thoughts?
