Pad Speed with....
  • Pad Speed with....
    Hi:
    I acquired a Meguiares/Porter Cable M/N 7335 DA with the following pads W7006, W8006 and W9006 with the following products Deep crystal ultimate compound, deep crystal polish and deep crystal carnauba wax.
    My question is what speed for each pad/product.
    I have two black vehicles that need some love, so is this the proper products following a good wash and clay job?
    Thanks in advance,
    RonW.
    Re: Pad Speed with....
    use 4-5
    slower for cutting
    higher for polishing/finishing
    DetailingByM.com
      Ult Compound: 4-5
      DC Polish: 2-3
      DC Carnauba: 2-3
      See the link below for more combos and clarifications:
      The list above is only a starting point. Ultimately which products you choose will be determined by your skill, the condition of the paint, how hard or "polishable" the paint is, and your personal preferences - especially with regard to your final wax selection. Some other things to keep in mind when working with the
      2018 Acura RLX Tech - Majestic Black Pearl
        Thanks, I saw the cheat sheet but it didn't have the pads listed that I have:
        RonW.
          I believe they are basically same aggressiveness pads except the 2.0 pads are machine washable. i.e. 9006 soft buff pad +/-= 9207 soft buff 2.0 pad, etc.
          7### = Cutting;
          8### = Polishing;
          9### = Finishing Pads
            don't go exactly by any guide or even what is said here.
            You need to let the paint tell you what it wants.
            I would hate for you to "go by what you've read" and then mess up your paint.
            Only use this as a reference.
            Like I said slower for cutting/removing defects and higher speed for polishing/cleaner wax. Wax/LSP slow.
            Now adjust this to your paint.
            DetailingByM.com
              No, you generally set the tool to a higher speed for correcting / compounding and a slower speed for finishing / polishing / waxing.
              Unless you're talking about arm speed?
                Originally posted by Please Wash Me Detailing View Post
                use 4-5
                slower for cutting
                Can you clarify your statement here Mario? Davey is right that your tool speed setting should be higher for defect removal and slower for polishing and finishing, but your arm speed may very well be the opposite of that. Your statement above could lead others to think you meant higher tool speed for polishing and lower tool speed for cutting.
                  I'm thinking of MF pads not foam, sorry.
                  DetailingByM.com
                    Even with MF pads, a higher speed is recommended for correcting / compounding and a slower speed for finishing.
                    Using Meguiar's D/A Microfiber Correction System - 2011 (https://meguiarsonline.com/forums/showthread.php?47855-Using-Meguiar-s-D-A-Microfiber-Correction-System) We are really excited to present our new DA Microfiber Correction System, a new concept in defect removal on factory cured paint. What's so new about it? This system,
                    But hey, whatever works...
                      Originally posted by RonW View Post
                      Hi:
                      Thanks in advance,
                      RonW.
                      All of the following advice is a guideline... the paint will react different car to car, year to year, even panel to panel... a jet black BMW is totally different to metallic Audi black..
                      that being said one thing that was omitted was pressure applied to the machine which translates to the paint,
                      Compound - heavy correction start machine on speed 5.. if need more power can move up to 6.. move the pad slowly... an inch a second and do at least 30% overlapping passes horizontally then when panel is covered switch direction and use vertical passes. It is in this stage you will want to apply the most pressure to the machine... just make sure the pad is still always rotating
                      Polish - finishing surface for wax - slower speed of 3 .... 4 if still removing light imperfections ... use light to moderate pressure depending on level of correcrion...if removing marring go to 3 ... arm speed is a little faster than compounding but not a lot.... remember you, ant the tool, the pad, and the product to do the work... so don't try to rush it.
                      Wax - slow the machine speed way down to 2 ... arm speed can be as fast as those dealership professional flame designers... can move much much much faster.. weight of the machine only ... still overlap and spread that problem duct evenly
                      Christopher Brown | OCDCarCare Los Angeles - Auto Detailing Services & Training Courses
                      OCDCarCare.com | FACEBOOK| Detailing Article Archive | INSTAGRAM
                      2013 Meguiar's/Ford SEMA Team, 2015 SEMA Car Crazy Corral
                        last sentence should read:
                        still overlap your passes as you spread the product out evenly
                          Speed variation
                          Speed varies with pressure and product as well. The w8007 is my favorite pad because it can conquor most projects by itself. You can use it to clean/buff, or polish to a certain extent. #3-4 with medium pressure, #4-5 light pressure......
