Hot Rims
  • Hot Rims
    Could I please get some advise as to whether I should be using the Hot Rims
    Re: Hot Rims
    Hello! Could I please get some advise as to whether I should be using the Hot Rims All Wheel & Tire Cleaner, or Hot Rims Aluminum Wheel Cleaner on my wheels? Any and all help is greatly appreciated. Thanks!
      Re: Hot Rims
      Hot rims all wheel cleaner would be great, but if you washed regularly, ordinary car wash soap works great with good tire /wheel brushes.
      I occassionally used APC+ at 10:1, pretty much put away my Wheel Brightener....
      "STRIFE" aka Phil
        Re: Hot Rims
        Esp if you clean them up well, then use the Brake Dust Barrier, soap and water is even easier.
        But if you are also going to have a dedicated wheel cleaner on the shelf, and you are cleaning often, the Aluminum Wheel Wash will be mildest, which isn't a bad thing.
          Re: Hot Rims
          Those are factory clear coated Mazda rims. So Hot Rims Wheel and Tire Cleaner is what you'd use on those type. But the APC above is good too.
          Show N Shine Car Detailing - Quality Care, Each and Every Time
            Re: Hot Rims
            hot rims is just fine.
            DetailingByM.com
