Detailer line question??
  • Detailer line question??
    I wanna use something cheaper than final inspection gallons to lubricate while claying cars??
    Will Last Touch Detailer Spray work? If so, what dilution rate should I use for this? I will only be using it for that....
    thanks,
    jon
    Hi there.
    I use LT mixed with water 50/50 as the directions state on the bottle for clay lube. Cheap and easy combo. I've used this combo with quick clay and the mild detail clay. I also clay the vehicle after washing, rather than drying off the vehicle then claying. The residual water act as additional lube.
    I also use the LT/water to clean door jambs after washing the car.
      I do the same while claying also, after wash just go right to clay, saves time and money.
      yeah FI gallon is 23.99. last touch detailer spray is 19.99 and thats great to hear that i can dilute it 50/50. big savings there.
      awesome info !!!
      thanks again.
      jon
        No prob.
        Good luck.
