Megs DA MF compound and polishing pads
  • Megs DA MF compound and polishing pads
    I have Megs ult compound and ult polish. Would there be a problem if I were to use the DA MF correction pads with these products? Or should I only use the DA MF compounds and polishes with the MF pads. I would be using the 6" pads.
    Thanks,
    Billy
    Re: Megs DA MF compound and polishing pads
    You can try them, but want to do a test spot. Will make them more agressive, so may or may not finish as nicely.
      Can you use them? Most definitely. Everyone uses different compounds and polishes with it. Is it recommended? Not really. Meguiar's created the D300 Correction Compound to be used in conjunction with the microfiber cutting discs.
      What are you trying to achieve? What machine are you going to use it with?
