Hello,
Is someone kind enough to answer some noob questions i have?
1) Not sure what this part of the car is called, but the bottom of the front of my car (Bumper?) is made from white plastic. It has a lot of scratches, bumps and road tar marks on it. Does Mequiar's offer a product to make it like new again? Maybe PlastX? I've used Ultimate compound on it and that brought a lot of colour (White) back to it, but there is still the scratches and marks on it. The worse part is that the scratches are black so it sticks out like dog balls!
2) Is there any reason to use Ultimate quick detailer over Ultimate wash and wax?
3) Is there any point in claying a car if your just going to use Ultimate compound on it anyway?
4) Is Ultimate protectant safe to use on the rubber trim around my windows etc...? is there a product made just for rubber?
5) I clayed my windows... Is there any point to this? I thought it might get rid of those water spots, but it didn't. How can I get rid of them?
6) Does cleaning my windows using something such as Meguiar's perfect clarity glass cleaner, remove the rain-x I applied?
7) My car has plastic hub cabs, the front ones get covered in a lot of brake dust. Is hot rims brake dust barrier safe on plastic?
8) Is it safe to clean foam applicator pads and re use them?
9) How do grit guards work? How do they stop practicals from floating through them?
10) What is the difference between Ultimate black and Ultimate protectant?
11) Microfiber wash mitt vs lambs wool wash mitt? Which is better?
12) How does Quick out work? Do you put it on, let it dry, then vacuum it out?
13) Is Ultimate protectant safe to use on plastics in and around under the hood and engine?
14) Why has the Ultimate range not extended to the tire parts of the car?
15) Does my car benefit from putting more then one coat of wax on?
16) If I was to use Ultimate quick detailer once a week, when would I need to wash my car?
There is a lot of questions here, and if anyone would take time out of their life to answer them I would greatly appreciate it.
