google 'nano diamond shield' i buy mine from pepboys. spray the entire atv with this. mud will just roll of when you hit it with a hose. I do mine every 6 months.
Thanks guys, i was leaning towards UQW and will just go a head and use it. Also I dont have a pep boys localy but if im ever out and pass by one i might just have to give nano dimond sheild try. Thanks again.
I have all ways waxed the outside of the fender wells, and have sprayed the inside with wd40, wiped off the excess, and allowed to dry. I have found that it allows mud and dirt to have a harder time sticking underneath. I also will sometime spray the bottom of the gram as well. On a side note linking the insider of my snowblower with wd40 allows the snow to slide in through the auger and out the chute very easily. I get less clogs this way as well. (I have an all metal snowblower though, and would not recommend spraying wd40 on plastic. I do this on the tab when I know I'm going in the mud and will be washing it anyway)
I've always had real good luck coating the entire bike with wd40 and wiping off the excess. The mud comes right off with a hose and the plastics shine right up. Has always worked very well for me
