I purchased the Klasse AOI & SG. I have used both. I can't hardly see the SG after it is applied. It really doesn't haze up very much. My question is: Does the SG really act as a protectant, the same as wax? Aslo, after I have applied the SG, is it a good idea to apply wax? Will the SG give as much shine as wax? I just would like to know more about what this SG stuff really is, & how it differs from car wax. Is it necessary to wash your car again, after you use clay on it?
Aoi & Sg
This is a Meguiar's forum ... but anyway.
SG works fine applied thinly so you don't need to see it after applying. How are you applying it anyway?
I personally don't like SG that much. NXT works well on top of AIO and easier to use imo, but since you've already got it, nothing wrong with it.
SG will protect your paint, and do a good job of it too. You can apply multiple layers of it, like any pure sealant.
You can use wax on top of it, if you like. SG has a nice shine but topping it with #16 or #26 will make it look even better.
You don't have to wash your car after you clay it, but you should definitely wash before, or rinse it and then after using your car shampoo, use it again for clay lube before the final rinse.
Re: Aoi & Sg
Good luck
SG over a wax will cause bonding issues thats why AIO should be used before SG to prep the surface.
NXT is a synthetic wax with ESPs and AIO is a polish/cleaner/protectant all in one so I'd say no they're not the same. Plus AIO is also acrylic based and NXT is polymer based.
I apply AIO as follows spread by hand on one panel let haze (1-2 minutes) then remove. The PC can be used but I haven't tried that yet.
Wax Differences
Synthetic Polymer/Sealant vs. Wax
Klasse SG
Now that I have heard how good of a protectant the Klasse SG is, I would like to put several more coats of SG on my car. However, here is the process in order of what I have done to my car: clay, AOI, one coat SG, one coat Meguir's #26. Don't I need to take off the #29 before I put more SG coats on? Also, how do I take off just the wax & not the AOI, or SG?
where are you at now (besides on the puter at home)? If only AIO and SG then add layers of SG then top with #26. If SG is topped with #26 you can a) remove and start over or b) wait a few weeks until the #26 has gone.
Depends on what you have done so far.
The AIO and SG should provide several months of protection. Not sure I would start all over right now. Why not wait it out til the mid to end of summer then start over? I don't think having 3 layers of SG will make it last any longer. I think the 3 layers hleps clarity and shine not sure though.
Its up to you and the time available. If it were me I'd wait.
#26 can't be removed without removing all the other products as far as I can tell.
That makes sense to me. Can I still put more layers of #26 on, & will it make it shine more? Also, I sure like your photo of the cute child with the glasses. Is that your son? I bet he already knows more than I do about detailing cars.
No that's my little girl. I took that pic over 4th of July last year. And she loves to help daddy wash his truck with sand and dirty wash mits. Oh well you can lead them to water but...
Thanks again
