Scuff marks
  • Scuff marks
    Hello guys, I'm new here, can guys recommend what products I can use to repair my plastic bumper and is it possible only by hand no machine?
    Re: Scuff marks
    You can tru some Ultimate compound by hand but it will take some time.
      Re: Scuff marks
      It looks like that paint has cracked, not going to be able to fix that by hand or machine.
        Re: Scuff marks
        I think you can definitely make it look better but it wouldn't be perfect. The blue/green mark looks to be paint transfer and that could be cleaned up with a cleaner polish such as Ultimate Compound. Anything other than paint transfer will be left behind. Do you have a D/A? Using a D/A will be more effective but it might be doable with hand.
        Check out my thread: Hit & Run Scuff Mark Repair 2008 Honda Civic Alabaster Silver Metallic.
          Re: Scuff marks
          Yeah there are cracks, will Ultimate Compound do the job?
          Don't have any machines...
            Re: Scuff marks
            the cracks are staying in
            the cracks are going to make attempting to remove the blue more difficult
            Have you priced out what it would be to have the piece repainted?
              Re: Scuff marks
              Yeah, working in UC is almost as liketly to just peel off the rest of the paint as remove some of the blue.
                Re: Scuff marks
                so guys it's no good to use UC then? it will just peel of the paint?
                  Re: Scuff marks
                  you have got a couple options as I see it
                  leave it as is
                  try some products and maybe make it worse
                  repaint
                  or any combination of the above
                    Re: Scuff marks
                    Ultimate Compound will remove the blue that was transferred from whatever came in contact with the bumper. The only way to fix the cracks, however, is to take the car to a body shop where they will sand down the bumper to it's base, fill if needed, and then fully repaint it. If the cracks run deep enough and are into the underlying substrate of the bumper, it may actually have to be replaced. That sort of depends on you, the body shop, and the insurance company.
