Re: sealant
this because the rioght step is D300 and than D301, but the sealant should be before wax right?
sealant
Re: sealant
Sure, if you'd like to apply a fully synthetic like NXT 2.0 or Ultimate Wax over the Finishing Wax of the DAMF System, go for it.
Re: sealant
What about the MF System, can I aply the sealant at top of the wax?
Re: sealant
Originally posted by imz4n View PostThe prep work will make the most difference IMHO. Use you compound to correct the paint, because the compound will actually put fine scratches in the clear coat, ( fine scratches is what helped remove the larger and deeper scratches ) , you then need to remove the fine scratches with a polish that has some correcting properties ( Ultimate Polish ) , for the wet, stick your arm into the paint to your elbow look , follow the first 2 steps with a pure polish like ( m07 ), no cutting power here it is only polish. When the car is looking great after the steps above then seal it and wait a day and wax it. IMHO
Wax or sealant alone is not going to make the paint look super deep, wet and shiny if it's full of swirls and other defects. That's not the purpose of a wax or sealant. For maximum gloss and depth, it's all the things Bob outlined above that really do the trick.
Re: sealant
guess i have been doing it wrong.. i always put the carnuba on first.. i figure the oils in it would bond to the paint and then the nxt would "lock it in"... eh lol. ill try it the other way.
Re: sealant
Re: sealant
I use the NXT 2.0 as my sealant and currently I've been using Dodo Juice Purple Haze carnauba on top of that. Gives a nice shine, when that runs out I'm gonna try the mirror glaze yellow wax on top of my sealant.
Thank you micheal for that detailed response! Will defo take that on board. Read so much out there about it's has all come intangled! I have a dark car (metallic grey Audi) so I am looking for that wet look personally but I also what the protection like water beeding when raining! Thanks again
Re: sealant
Originally posted by Michael Stoops View PostLooks like we might a tiny bit of confusion happening here.
First off, let's look at what these two products, carnauba wax and sealant, really are. Essentially, both do the exact same thing but in slightly different ways; they are last step products (ie, the last product you apply to the paint in the detailing process) and both provide a level of protection and gloss to the finish. Neither is the primary source of gloss, however, as that primarily comes from all the prep work you do before hand. Sealant, which can be looked at as synthetic waxes, will tend to last longer than carnauba waxes do, and may tend to impart a brighter and crisper shine than carnaubas do. Visual differences between the two groups, provided your eyes can detect them, are really a matter of preference.
There is no "need" to use both - one or the other should be able to stand on its own merits. There is a population of folks who like collecting waxes and sealants and trying them out in different combinations to see what sort of visual differences they might achieve, especially on different colored vehicles. As a very general rule of thumb, sealants are often regarded as imparting the bright, crisp shine noted above (some will negatively comment on how certain sealants can make a paint look like plastic, or like it's been wrapped in plastic wrap) while carnauba waxes are usually considered to give a warmer, deeper, perhaps wetter look, especially on darker paints. None of this is good, bad or otherwise, it just is. If you prefer the look of a bright, crisp shine on a black car, then that's your opinion and it's what you like on your car. Nobody can tell you you're wrong.
Now, when using both type of product on the same car it is generally accepted that the sealant is applied first, allowed to haze before wiping off, and then allowed to cure for 12 to 24 hours before applying either a second coat or a carnauba wax. This is due to a few factors: with the synthetic sealant being the longer lasting of the two it makes sense to lay it down first and then put the sacrificial layer on top of it; people often use both in order to get the longevity and protection of the sealant and the look of the carnauba, so the carnauba needs to be applied last if you want to enjoy its visual characteristics; some sealant manufactures state that their sealant must be applied to completely bare paint or it won't bond properly (Meguiar's does not make this claim, by the way).
So, again, there is no real "need" to use both types of products, although you certainly can if that's what makes you happy. And for the record, our NXT Tech Wax 2.0, Ultimate Wax, and M21 are all 100% synthetic sealants with no actual carnauba wax in them.
Re: sealant
Re: sealant
Originally posted by andikendall View PostCheers Marc! Would you recommend a sealant to use or will next gen 2.0 be do it
Originally posted by BillE View PostNXT 2.0 is a great choice. Ultimate Wax (liquid or paste) is a step up.
Just remember, Wax first THEN sealant, IF you want to go down that road.
Bill
Re: sealant
Bill
