3inch backing plate to use with G110
  • 3inch backing plate to use with G110
    Which 3" backing plate do I purchase when using a G110v1.
    Meguiars W63 or the Meguiars S3BP?
    If I purchase the W63 will it come with the threaded bolt so I can attach it to the G110v1.
    Thanks.
    Re: 3inch backing plate to use with G110
    You need the S3BP. This is the appropriate backing plate for your g110v1 or any D/A polisher for that matter.
    The W63 is for the rotary.
      You will want to use our S3BP Professional 3 Inch Backing Plate. If you are going to use this for our 4 inch Soft Buff Pads, the pad part #'s are the W8204 4" Yellow Foam Polishing Pad & W9204 4" Black Foam Finishing Pad. The W63 is for a rotary.
      Nick Winn
      Irvine, CA
      nawinn@meguiars.com
        This backing plate is also perfect for the 3" Microfiber cutting and finishing discs!
          thank you for your fast response. Time to purchase the correct tools for the job.
            Getting ready to buy some new products. I was looking for the pads above and backing plate to use in between the ribs on top of my vehicles. Are the numbers still good and can I order from Meguiars. I looked on Meguiars direct.com site and couldn't find them. Anyone order some recently?
              Certain Meguiar's Professional Mirror Glaze & Detailer Line products are not sold direct. They can be purchased through distributors, including auto body or automotive paint supply stores which sell our products, and on-line detailing supply companies.
              Nick Winn
              Irvine, CA
              nawinn@meguiars.com
                Will the adapters supplied with the S3BP fit a W6814mm to enable that backing plate to be used on a DA?
                I have inadvertently purchased a W68 instead of a W68DA.
                I have also bought a Rotary to DA adapter but that is a 5/8 to 5/16 adapter when the backing plate is 14mm so the adapter is no good to me either.
                Now if one of the S3BP adapters will fit on the W68 then I can kill two birds with one stone
                2012 Ebony Black Kia Optima Platinum
