How do I use 105 without it drying up and also how do I remove the dried up 105 dust because yesterday I had problems using 105 and I just left it until today to finsh the detail and there's dried dust everywhere will it etch the paint
How to work 105
Re: How to work 105
Since you're using a DA it may well be that you're using too much M105 and maybe not working it quite long enough. M105 can be very finicky on a DA, especially if you're dealing with very dry paint. In many cases Ultimate Compound is a better choice as it was designed for DA use and provides a much longer buffing cycle with that tool than M105 does. If you've got some M105 that has sort of gummed up on the surface, try spraying just a little bit of plain water on it, then put just a couple drops of M105 onto your polishing pad and go over the area quickly to break down the gummed product, and wipe it off immediately. After that, use M105 very sparingly when working with a DA.Michael Stoops
Re: How to work 105
Originally posted by rossi6998 View PostMike,
I had heard that you can use a little quick detail spray on the D/A pad to rejuvenate M105 when it starts drying to quick. Your thoughts?
But before you start experimenting with spraying QD or water, try backing way down on the amount of M105 you use. On a fully primed pad, when working with a DA, you may find that just a few drops of M105 is all you need.Michael Stoops
