Paint cleaner ?
  • Paint cleaner ?
    If I use deep crystal paint cleaner do I still need to clay because I ran out of lube or do I need to clay then use the paint cleaner
    Re: Paint cleaner ?
    You only really need to clay if the paint feels rough to the touch. If it doesn't feel rough then there's no problem just washing, paint cleaner, wax. You are correct, however, that claying would go before the paint cleaner if you need to do both.
      Re: Paint cleaner ?
      yes, you'll need IMHO...
      because clay and paint cleaner serve different purpose..
      Clay to remove above clear coat defect
      Paint claner to remove under clear coat defect
      except your paint it as smooth as glass, you'll need claying to achive maximum result
      Proud to be part of Meguiars Family
        Re: Paint cleaner ?
        The proper way would be clay then paint cleaner. They do different things, so one doesnt replace the other.
        Of course you only need to do what you want to, and can always clay next time.
        You could try claying with the soapy water from when you are done washing.... but it might degrade the clay if stored for a while.
          Re: Paint cleaner ?
          i went to a meguairs rep and got some blue mild clay but he didnt have any qd so he gave me uqd how good is that as clay lube im also getting final inspection next week 4 gallon bottle so ill have plenty of that for lube
            Re: Paint cleaner ?
            Just to point out, Last Touch can be diluted 1:1 for clay lube if available up there, so would last even longer.
            I dont know if I would bother using a half bottle of UQD (more expensive, not as good) when just waiting a week.
              Re: Paint cleaner ?
              Do not use UQD as a clay lube. Way too slick and way too expensive to really be effective IMHO.
              Tedrow's Detailing
              845-642-1698
