1500/2000 grit sanding marks
  • 1500/2000 grit sanding marks
    Tried about everything I have with the DA on some GM paint. Microfiber cutting with D300, foamed wool with M105 and M04, orange LC with M105 and M04. I could have polished the entire car by the time it takes me to get these sanding marks off half of a hood. The only thing I haven't tried that I have is Scratch-X. Should I try by hand with Ultimate Compound or Clear Coat Safe Rubbing Compound? Any help?
    Re: 1500/2000 grit sanding marks
    IMHO, you'll need rotary to remove sanding mark... and again, you'll need to do many practices before you'll be able to use rotary >.<
    DA are just not strong enough to remove sanding mark, but a perfect tool for beginer to remove swirl and scratch... ( not a deep deep scratch )
    Proud to be part of Meguiars Family
      After more work I've got some of it coming out by hand on a microfiber applicator and D300 or M105. It's just time comsuming and wearing me out. Anything a little more aggressive I can use by hand? I'm about to go get some CC Safe Compound if it'll work a little faster. I can get what's left with the DA and D300.
